2005 Avalon - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-12-2005, 10:53 AM   #1 (permalink)
chumad@cox.net
Guest
Posts: n/a
View chumad@cox.net's Photo Gallery
2005 Avalon
Love this car but have 1 annoying issue, when under hard acceleration,
the car smells like rotten eggs inside. Tried premium gas, doesn't
matter if I have outside air on or not. Anybody else with this?
Chuck
Old 10-12-2005, 11:16 AM   #2 (permalink)
High Tech Misfit
Guest
Posts: n/a
View High Tech Misfit's Photo Gallery
Re: 2005 Avalon
[email]chumad@cox.net[/email] wrote:
[color=blue]
> Chuck[/color]
My best guess is that the problem is not the octane of the gas, but the
quality. Try a higher quality gas brand with little to no sulfur in it.
Old 10-12-2005, 11:58 AM   #3 (permalink)
Dan J.S.
Guest
Posts: n/a
View Dan J.S.'s Photo Gallery
Re: 2005 Avalon
<chumad@cox.net> wrote in message
news:1129132425.830202.72350@g47g2000cwa.googlegroups.com...[color=blue]
> Chuck
>[/color]
Seems all toyotas do this... my 2003 4runner is REAL bad... but that is my
biggest complaint and i can live with it...
Old 10-12-2005, 01:48 PM   #4 (permalink)
C. E. White
Guest
Posts: n/a
View C. E. White's Photo Gallery
Re: 2005 Avalon
> Chuck[/color]
Toyota TSB EG003-03
Introduction:
Some owners of Toyota vehicles may experience a sulfur like or rotten egg
odor from the exhaust system. Sulfur is a natural component of crude oil
from which gasoline is refined and the amount of sulfur can be decreases
through the refining process. The amount of sulfur in fuel in CA is
regulated, however gasoline sold in other states can have substantially
higher sulfur content. Sulfur content also varies considerably between
gasoline brands and locations.
Applicable vehicles:
All models
Repair procedure:
A sulfur odor emitted from the vehicle tailpipe does not necessarily
indicate that there is an issue with the engine's condition, but is most
likely directly related to the fuel. If the vehicle is exhibiting an
excessive sulfur odor, the following checks should be performed:
If the MIL light is ON, check for DTCs and repair as necessary
If no trouble is found after performing the above check, recommend the
customer try a different source of fuel.
Replacement of oxygen sensors, air/fuel ratio sensors or catalytic
converters will not reduce the odor and therefore will not be considered
warrantable.
Regards,
Ed White
Old 10-12-2005, 03:48 PM   #5 (permalink)
Dan J.S.
Guest
Posts: n/a
Re: 2005 Avalon
"C. E. White" <cewhite3@mindspring.com> wrote in message
news:qUc3f.13893$q1.3192@newsread3.news.atl.earthlink.net...[color=blue]
> news:1129132425.830202.72350@g47g2000cwa.googlegroups.com...[color=green]
>> Chuck[/color]
> Toyota TSB EG003-03
> Introduction:
> All models
> Repair procedure:
> warrantable.
> Regards,
> Ed White
>[/color]
Funny, there is a TSB on my 03 4runner that replaces the cat and it
supposedly reduces the odor... what makes no sense is that my friend's Pilot
does not produce this smell and we both get gas at the same station.
Old 10-12-2005, 04:45 PM   #6 (permalink)
C. E. White
Guest
Posts: n/a
Re: 2005 Avalon
"Dan J.S." <me@hyperx.com> wrote in message
news:11kqtlmknah2n27@news.supernews.com...
[color=blue]
> Pilot does not produce this smell and we both get gas at the same station.[/color]
Toyota has a tradition of having engine management / catalytic converter
strategies that are more sensitive to sulfur than other brands. At one time
or another virtually every manufacturer has had this concern. I am not sure
what Toyota is doing differently. However, I am certain that if you are
getting the rotten egg smell, there is sulfur in your gas. The fact that you
can smell it and your buddy can't just means that Honda has hit on an engine
management strategy that is preventing the creation of sulfur dioxide. Maybe
instead, they are creating sulfuric acid (another possible creation when you
have sulfur in the gas). You can be sure if there is sulfur in the gas, it
is reacting with the other elements in the exhaust stream to create
something. Whether or not the compound being created by Toyota is better or
worse than the compound being created in a Honda catalytic converter, I
can't say.
I do recall that Toyota (and Ford, and GM, and....) have from time to time
tried to address the rotten egg smell by revising the converters. Currently
only Toyota seems to have a major problem with the smell. Toyota has a TSB
for the Matrix that calls for reprogramming the PCM and replacing the
catalytic (see
ttp://forums.genvibe.com/zerofile/4746/1zzsulfursmell.pdf ). Maybe
something like this is in the works for the Avalon as well.
The suggestion to change gas brands is little more than a go screw yourself
response. In many locations, all the unleaded gas comes from the same stocks
no matter who's name is on the station. While the additives may be
different, the basic gasoline is the same, and therefore changing brands
won't necessarily change the sulfur content (although it might because the
base stock for that particular day's delivery came from a different lot).
Eventually the government will tighten the requirements and reduce the level
of sulfur in all gas. When this happens, your Toyota will be fixed.
Personally I'd like someone more knowledgeable than me to explain the
advantages / disadvantages of the Toyota emission control system. I don't
think Toyota engineers are stupid, so they must have made a different
tradeoff than other manufacturers for some reason.
It was not so long ago that Shell in Louisiana got in trouble for selling
fuel with so much sulfur that it was actually damaging fuel gauge tank
sensors. I can only guess how damaging this must be to converters (and
noses).
Regards,
Ed White
Old 10-12-2005, 06:22 PM   #7 (permalink)
ron
Guest
Posts: n/a
View ron's Photo Gallery
Re: 2005 Avalon
I live in Northern California and I believe Ed and the TSB are
correct. Our gasoline sucks for mileage compared to out of state gas
in my vehicles. I've never noticed the "rotten egg" smell from mine.
BUT
I have followed vehicles from other states in Oregon/Wasigton/Idaho
and you can definitely smell the odor, of some of them. It seems more
pronounced on long grades where engine is under load. Didn't pay
particular attention to makes.
So I'd suggest trying different brands also or living with it.
Ron
news:Etf3f.13949$q1.10469@newsread3.news.atl.earthlink.net...[color=blue]
>[color=green]
>> friend's Pilot does not produce this smell and we both get gas at
> converter strategies that are more sensitive to sulfur than other
> brands. At one time or another virtually every manufacturer has had
> this concern. I am not sure what Toyota is doing differently.
> However, I am certain that if you are getting the rotten egg smell,
> there is sulfur in your gas. The fact that you can smell it and your
> buddy can't just means that Honda has hit on an engine management
> when you have sulfur in the gas). You can be sure if there is sulfur
> in the gas, it is reacting with the other elements in the exhaust
> stream to create something. Whether or not the compound being
> created by Toyota is better or worse than the compound being created
> in a Honda catalytic converter, I can't say.
> to time tried to address the rotten egg smell by revising the
> converters. Currently only Toyota seems to have a major problem with
> the smell. Toyota has a TSB for the Matrix that calls for
> reprogramming the PCM and replacing the catalytic (see
> yourself response. In many locations, all the unleaded gas comes
> from the same stocks no matter who's name is on the station. While
> the additives may be different, the basic gasoline is the same, and
> therefore changing brands won't necessarily change the sulfur
> content (although it might because the base stock for that
> particular day's delivery came from a different lot). Eventually the
> government will tighten the requirements and reduce the level of
> the advantages / disadvantages of the Toyota emission control
> system. I don't think Toyota engineers are stupid, so they must have
> made a different tradeoff than other manufacturers for some reason.
> selling fuel with so much sulfur that it was actually damaging fuel
> gauge tank sensors. I can only guess how damaging this must be to
> converters (and noses).
> Regards,
> Ed White
>[/color]
Old 10-12-2005, 09:37 PM   #8 (permalink)
Philip
Guest
Posts: n/a
View Philip's Photo Gallery
Re: 2005 Avalon
Nevermind the choice of fuel, find out how exhaust is getting inside the car
while moving. Trunk weather seal torn?
> Chuck
>[/color]
Old 10-12-2005, 11:19 PM   #9 (permalink)
chumad@cox.net
Guest
Posts: n/a
Re: 2005 Avalon
Thats what I was thinking, a bit disappointed that $30,000 has this
issue but it seems that its quite common. At the 5,000 service I guess
I'll bitch a little and see what the dealer suggests, thanks all for
replying. Misery loves company you know....
BB code is Off
Smilies are Off
[IMG] code is Off
