Re: 93 Geo Prizm (Toyota Corolla) acting speedometer
I had a 92 Tercel that done this. It gets much worse in colder weather. Mine
would emit a horrendous buzzing noise at the critical point of 45mph. I
could hardly hear the radio. Apparently there is a set of gears or teeth
somewhere on the cable behind the instrument cluster that requires
lubrication, otherwise it will "catch" at about 45mph for some reason. The
shop I took the tercel to told me this and they lubricated the problem but
this was only a temporary fix. They had to take the instrument cluster out
to get to it I beleive, I'm not sure. The more permanent fix of course would
be to replace the part(s). Sorry I don't know that much about it, I'm only
going by what the guy told me.
Casey
<sharefreemusic@gmail.com> wrote in message
news:1131222407.945134.177410@f14g2000cwb.googlegroups.com...[color=blue]
> I am having this exact same problem (either 0 or 65 showing on
> speedometer) on my 93 prizm. how do i check to see if it is catching? i
> would love some help with this!
> thanks,
> Chris
> Charles @ Kankakee wrote:[color=green]
> > "denoxis" <google@deniznet.com> wrote in message
> > news:1129231566.369992.206870@g47g2000cwa.googlegroups.com...[color=darkred]
> > > Hi,
> > > I have read some postings but I'm not sure what the problem is since I
> > > haven't seen anybody with this particular behaviour.
> > > After some radiator/timing belt job, the car's speedometer started
> > > acting weird. It shows 0 MPH until I reach 40 - 50 MPH. When I reach
> > > 40-50 MPH, it goes to 65 MPH instantly (even though I'm not that fast)
> > > When I slow down, needle goes down dead to 0 MPH again. It is[/color][/color][/color]
automatic[color=blue][color=green][color=darkred]
> > > transmission but there is NO shifting problem at all.
> > > I mentioned to the mechanic who did the timing belt job, and he said[/color][/color][/color]
it[color=blue][color=green][color=darkred]
> > > must be the sensor since these models don't use a wired system.
> > > Any opinions?
> > > Thanks.
> > >[/color]
> > If it's a mechanical speedometer, check to see if it's catching. We had[/color][/color]
an[color=blue][color=green]
> > old speedometer in our Corvair do almost exactly the same thing.
> > Charles of Kankakee[/color]
>[/color]
