OBD II code - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2005, 01:53 PM   #1 (permalink)
wenmang@yahoo.com
Guest
Posts: n/a
View wenmang@yahoo.com's Photo Gallery
OBD II code
Hi,
Are OBD II codes universal or unique for each model? IF yes, where can
I find a website that has those DTC info listed?
Thanks.
Old 10-24-2005, 03:09 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: OBD II code
<wenmang@yahoo.com> wrote in message
news:1130176387.074619.28710@z14g2000cwz.googlegroups.com...[color=blue]
> Hi,
> Thanks.
>[/color]
Yes and no. The Society of Automotive Engineers specifies a list of OBD II
codes that are universal for every model although not every code applies to
every model. For example, an in-line 4 cylinder engine does not have a
"bank 2."
Check out [url]http://www.obdii.com/codes.html[/url] for a list of universal codes and
links to some more explanations of how OBD II works.
Ray O
correct the return address punctuation to reply
Old 10-24-2005, 06:08 PM   #3 (permalink)
TeGGeR®
Guest
Posts: n/a
View TeGGeR®'s Photo Gallery
Re: OBD II code
[email]wenmang@yahoo.com[/email] wrote in
news:1130176387.074619.28710@z14g2000cwz.googlegroups.com:
[color=blue]
> Hi,
> Thanks.
>[/color]
Codes that begin P0 (P-zero) are mandated by the federal EPA and are
identical in all cars sold in the US and Canada.
Codes that begin with P1, P2, etc, are "enhanced" codes that are NOT
mandated by the EPA. Automakers add them at their own discretion.
Ray O has given you the main site for the mandated codes.
For Toyota specific codes, you need to know the exact number, the you can
punch it in here:
[url]http://actron.com/code_lookup.php[/url].
AutoZone in the US (other than California) will read your codes for free.
TeGGeR®
Old 10-28-2005, 12:38 PM   #4 (permalink)
daumus
Guest
Posts: n/a
View daumus's Photo Gallery
Re: OBD II code
"" wrote:[color=blue]
> Hi,
> where can
> Thanks.[/color]
This link lists generic OBD II DTC.
[url]http://www.autotap.com/generic_trouble_codes.html[/url]
daumus
Posted using the [url]http://www.autoforumz.com[/url] interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: [url]http://www.autoforumz.com/OBD-II-code-ftopict143631.html[/url]
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=693924[/url]
Old 10-28-2005, 06:30 PM   #5 (permalink)
TeGGeR®
Guest
Posts: n/a
Re: OBD II code
"Jeff Strickland" <crwlr@yahoo.com> wrote in
news:7JudnZc2NsiwDP_eRVn-uA@ez2.net:
[color=blue]
> I'd like to explore the enhanced (P1 and P2, etc.) codes. The lists
> that I have seen seem to show that while all codes are not always
> used, most codes that are used always mean the same thing. That is,
> all cars won't produce a P1234 (ficticious code that I pulled out of
> my ass), but when a car does produce a P1234, then it normally means
> the same for all cars that produce a P1234. I do not argue that the
> codes are enhanced, I conpletely agree that they are. But my very
> limited experience is that codes are uniform with a few exceptions.
>[/color]
P1, P2, P3, etc codes are manufacturer specific, as they are not mandated
by the EPA.
It wouldn't surprise me to see some standardization of the code numbers
between manufacturers, but they are not forced by law to make them the
same.
TeGGeR®
Old 10-29-2005, 12:39 PM   #6 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
Re: OBD II code
"TeGGeR®" <tegger@tegger.c0m> wrote in message
news:Xns96FDBC5FA3AAFtegger@207.14.113.17...[color=blue]
>[color=green]
>>[/color]
> by the EPA.
> same.
>[/color]
Actually, today there are only P0 and P1 Codes. Check it out ...
[url]http://www.obdii.com/dtcanatomy.html[/url]
But, you were right, only P0 are standardized by regulation, the P1 codes
may or may not carry over among different manufacturererers.
Old 11-06-2005, 01:21 AM   #7 (permalink)
Steve H
Guest
Posts: n/a
View Steve H's Photo Gallery
Re: OBD II code
Got this from a class I was in recently, thought it was interesting.
How to basically read OBDll Standardized Diagnostic Trouble codes.
The codes start with a letter:
The trouble code area:
P- Powertrain
B- Body
C- Chassis
U- Network Fault
Who created this code:
0- SAE defined code
1- Manufacture defined code
2- Manufacture (they ran out of codes for 1 so they expanded to "2")
System:
0- Total system
1- Air-fuel control
2- Air-fuel control
3- Ignition system or misfire
4- Auxiliary Emission Controls
5- Idle or speed controls
6- Computer system (PCM or I/O)
7- Transmission
8- Non-computer controlled Powertrain
The last two digits indicate the specific problem area
So the code P1711 would tell us:
P- Powertrain
1- It's a manufacture's code
7- Transmission
11- Transmission oil temperature circuit out of range
and the code P0300 would tell us:
P- Powertrain
O- It's a SAE mandated code
00- random misfire detected
Stephen W. Hansen
ASE Certified Master Automobile Technician
ASE Undercar Specialist
[url]http://autorepair.about.com/cs/troubleshooting/l/bl_obd_main.htm[/url]
[url]http://www.troublecodes.net/technical/[/url]
news:Xns96F9B87FDBC3tegger@207.14.113.17...[color=blue]
>[color=green]
>> Hi,
>> Thanks.
>>[/color]
> punch it in here:
> TeGGeR®
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
