Help - 2000 Camry fan switch partially working? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2005, 06:11 PM   #1 (permalink)
Reckless
Guest
Posts: n/a
View Reckless's Photo Gallery
I have a 2000 Camry where the fan switch only works on off or high. Has
this happened to anyone else? I haven't started taking it apart yet, but I
assume it's just the switch. If anyone knows of a quick test, please let me
know.
Thanks
Old 11-11-2005, 12:15 AM   #2 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
Re: Help - 2000 Camry fan switch partially working?
On Thu, 10 Nov 2005 18:11:32 -0500, "Reckless" <hmarshall@sprint.ca>
wrote:
[color=blue]
>know.[/color]
It's more than likely the speed control resistor - Follow the power
leads from the fan motor back, and four or five wires will go to a
connector that is fastened to the side of the heater duct with a
screw.
Turn off the power before opening this up, and do not test the motor
under power with the resistor pulled out. The resistor has to live in
the fan airflow with the power on, or it will quickly burn up. And if
you grab it while it's on, your fingers are going to have grill marks
like a steak.
The resistor gives you the Low and Medium speeds, and the fan switch
sends full voltage straight to the motor on High. If the resistor
goes open on the highest medium setting segment you lose everything
below High, if the last segment goes open you only lose Low.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
BB code is Off
Smilies are Off
[IMG] code is Off
