Removing Control arm from 97 tercel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2005, 12:42 PM   #1 (permalink)
TomC
Guest
Posts: n/a
View TomC's Photo Gallery
I need to replace bent lower control arm from my daughters Tercel. I
found a nice one at junkyard. Also found that the main pivot bolt the
connects the arm to the frame is a hard one to handle by hand. I was
able to loosen the bolt by hand, turning it about 4 time. After that,
it became stuck. Plan on putting impact wrench on it tonight, but am
concered I will snap the bolt. I guess I would like to know if this
bolt is suppose to be this stubborn, and if this is normal.
Old 11-21-2005, 04:05 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Removing Control arm from 97 tercel
"TomC" <cochran.thomas@mayo.edu> wrote in message
news:1132598536.115969.32800@g47g2000cwa.googlegroups.com...[color=blue]
>[/color]
It is common for suspension bolts to corrode over time and become difficult
to turn. Before you put the impact wrench to it, try giving it a shot of
penetrating fluid.
Ray O
correct the return address punctuation to reply
BB code is Off
Smilies are Off
[IMG] code is Off
