Re: Radio Problems 3 in 1 combo Model 16806 95 Camry XLE
<tschoenbachler@eoncc.com> wrote in message
news:1132600972.550811.309510@g14g2000cwa.googlegroups.com...[color=blue]
> Got a strange problem with my radio in my camry. After starting the
> car - usually when it's been sitting a while - the radio will not turn
> on - it was on when I shut off the car. If I wait a few minutes, it
> will eventually - most of the time anyway - turn on. Sometimes if I
> stop and restart the car it will then come on. There is power to the
> radio because it lights up when I turn on the lights - that's the
> lights inside the radio not the LED panel. Any ideas short of swapping
> the radio out? Thanks in advance schoeto...
>[/color]
I believe there are 3 power sources for your radio - one tied into the
lighting system, one that is always hot for radio memory, and one that is
switched to accessory/ignition. You need to check all 3 power sources.
Ray O
correct the return address punctuation to reply
