Re: 2002 Corolla Brake problem/etc.
"Indu Prakash" <leolite1@sbcglobal.net> wrote in message
news:fArgf.350$KA3.71@newssvr31.news.prodigy.com...[color=blue]
>I have this annoying problem with my Corolla. Every day I back out of the
>garage-stop and then drive forward. Now the first time I brake I hear a
>crank/metallic noise .. but no more noise of subsequent braking. This
>happens again if I stop-reverse-stop and then go forward. The dealer said
>that there was some clip which was loose and I shouldn't worry about it ??
>I took out the tires and closely inspected the brake but couldn't see any
>loose clip.
>[/color]
If you are hearing a whining and clanking noise that sounds almost like a
distant vacuum cleaner from the front of the car for a few seconds and you
have ABS, it is the normal operation of the ABS system doing a self-check of
the actuator.
[color=blue]
> Secondly recently I've occasionally started hearing squealing noise when I
> make a sharp right-turn ??[/color]
If the squaeling is coming from under the hood, then it is possible the belt
that drives the power steering pump is slipping. If it is coming from the
tires, you need an alignment or your tires are under-inflated, or both.
[color=blue]
> And thirdly, sometimes when its colder (I'm in WI) when I shift the gear
> from reverse to forward the car lurches a bit as soon as I release the
> brakes. Is this a diferent problem or is it somehow linked to the brake ?
> Thanks in advance for an advice ..[/color]
The lurching is normal in colder weather because the engine tends to idle a
little higher until it is warmed up.
Ray O
correct the return address punctuation to reply
