Re: Need a Toyota Guru-Quick!!! '95 Avalon xls has a cylinder 6 misfire that won't go away
"BENJY613" <benyamintripp@gmail.com> wrote in message
news:1edbdfcd2d379cfcd63c13146809e96c@localhost.talkaboutautos.com...[color=blue]
> My well maintained( gets reg tune ups and oil changes )..Mil keps poping
> up
> od2 reads cylinder 6 misfire...A tune should not be necessary ,,Whats the
> next step ..Changing the coil?? and what does that cost me ??
> Frustrated in Jersey,
> Ben
>[/color]
Dear Frustrated,
Was the MIL blinking or on solid? If it was blinking, the system detected
at least 1 misfire every 200 engine revolutions and there is the possibility
that the catalyst will be ruined. If it is on solid, then it needs to
detect a misfire every 1,000 revolutions on 2 trips.
The factory service manual has a long list of possible causes, starting with
the ignition system. For starters, when the tune-up was done, were original
Toyota platinum-tipped spark plugs used? If not, then that is a likely
cause. Start by using OEM plugs.
Check for spark by pulling the coil and spark plug, inserting the spark plug
in the coil, and crank the engine to check for spark.
After that, you will need an oscilloscope to check the injector firing
pattern and a multi meter and factory service manual to check everything
else.
Good luck!
Ray O
correct the return address punctuation to reply
