Fixing Cracked Block - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2005, 07:48 AM   #1 (permalink)
jor
Guest
Posts: n/a
View jor's Photo Gallery
RayO and others have panned Bar's Leak and other similar products. I tend to
agree with their comments but I am in a bit of a bind on a non-Toyota (old
Ford pickup). I just dropped a rebuilt engine in. For the rebuild I used a
block that had been cracked. The machinist fixed the crack (between freeze
plugs) but it appears to be leaking. The leak is minimal right now, just a
tiny bit of residue. I really don't want to pull this engine again so I am
looking for a fix. I should add that the rebuild itself if a quality build
and that I push this engine a bit (maybe up to 5 or 5.5K RPM on occasion. So
what do everyone suggest for something to prevent the leak from gettng
worse? Oh, I'm in Arizona and we only get a few days of freezing
temperatures. Heat is the culprit around here. Thanks.
jor
Old 11-24-2005, 09:28 AM   #2 (permalink)
C. E. White
Guest
Posts: n/a
View C. E. White's Photo Gallery
Re: Fixing Cracked Block
"jor" <jor@jor.com> wrote in message
news:8qGdncITe_YEWRjenZ2dnUVZ_tmdnZ2d@comcast.com...[color=blue]
> to agree with their comments but I am in a bit of a bind on a non-Toyota
> (old Ford pickup). I just dropped a rebuilt engine in. For the rebuild I
> used a block that had been cracked. The machinist fixed the crack (between
> freeze plugs) but it appears to be leaking. The leak is minimal right now,
> just a tiny bit of residue. I really don't want to pull this engine again
> so I am looking for a fix. I should add that the rebuild itself if a
> quality build and that I push this engine a bit (maybe up to 5 or 5.5K RPM
> on occasion. So what do everyone suggest for something to prevent the leak
> from gettng worse? Oh, I'm in Arizona and we only get a few days of
> freezing temperatures. Heat is the culprit around here. Thanks.[/color]
Why not try the bars leak? Ford puts it in vehicles at the factory...
Ed
Old 11-24-2005, 01:01 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
> jor
>[/color]
This scenario is where I would recommend Bars Leak - a case where the cost
of a normal repair would be out of line with the vehicle's value or the
owner's willingness to pay for the repair.
Ray O
correct the return address punctuation to reply
Old 11-25-2005, 08:06 AM   #4 (permalink)
jor
Guest
Posts: n/a
> jor[/color]
Thanks, guys. Bar's Leak it is! I examined the block closely yesterday and
it doesn't appear to be leaking so I'm keeping my fingers crossed. The
lesson here is to stay away from cracked blocks. I was looking for a good
390 builder, couldn't find one and took a chance. Thanks.
jor
Old 11-27-2005, 01:05 AM   #5 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
> jor[/color]
Well, for starters, stop pushing it to the 5 or 5.5k RPM markers. Give the
poor old thing a break before it breaks.
Old 11-27-2005, 10:03 AM   #6 (permalink)
Philip
Guest
Posts: n/a
View Philip's Photo Gallery
What is an "old Ford?" 289 or one of the long stroke engines ... it makes
a difference regarding winging the RPM up to 5500. Either way, these old
push rod engines were not intended for that sort of thing. Chevys are sort
of elastic but Fords store those abuses and then one day explode like so
much glass.
> jor
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
