Timing Belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2005, 06:15 PM   #1 (permalink)
Charles Pisano
Guest
Posts: n/a
View Charles Pisano's Photo Gallery
Timing Belt
How much should it cost to get it changed out on my 01 Camry (4 cyl)? Is
there some kind of prefered belt I should have put on (kevlar -maybe)?
I guess I'll take it to a dealer for this and I imagine they warrant
it? While they have it apart , I'll have 'em do the hoses, belts and
what else should fall in line with this job? I imagine the coolant is
something they'd have to renew anyway.
TIA
CP
Old 11-24-2005, 09:16 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Timing Belt
"Charles Pisano" <pisanochas@webtv.net> wrote in message
news:20702-438657A6-257@storefull-3273.bay.webtv.net...[color=blue]
> TIA
> CP
>[/color]
You may want them to also replace the water pump as there is only a little
extra labor plus the cost of the water pump.
Ray O
correct the return address punctuation to reply
Old 11-24-2005, 10:50 PM   #3 (permalink)
Joey
Guest
Posts: n/a
View Joey's Photo Gallery
Re: Timing Belt
Charles Pisano wrote:
[color=blue]
> TIA
> CP
>[/color]
Charles,
The normal job requires removing the plastic shroad covering the belt.
One engine mount has to be temp removed. I would always use a geninue
Toyota belt and there is only one kind. They should last over 60K
miles. The water has to be drained if the hoses are to be replaced
which is a good idea. Belts too. The water pump is actually driven by
the timing belt so it's always good to replace that too. If the timing
belt is being replaced for the second time I always replace the idler
pulley and tension spring that the belt rides on. This should leave
everything except the thermostat but that's fairly easy to get to later
if it gives problems. I've heard there is a new thermostat available
that always sticks in the open position when it fails--sounds good. If
you want more info on this type job, there are a few sites on the
internet that tell how to change this timing belt.
Joey
Old 11-25-2005, 08:22 AM   #4 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
Re: Timing Belt
I was surprised when I asked dealer to do waterpump at same time (75k
miles) - and he said they'd check it and replace if necessary. They said it
wasn't necessary but that the oil pump o-ring was leaking so they replaced
that. 60k miles later and no water pump problems yet.
I has a special offer dealer coupon (check on line) that made the repair
~$200 on a 4 cyl (offer is still available but might have gone up $10-20).
Sample discount coupon -
[url]http://dealer.webmakerx.net/Images/Site/Toyota-of-Santa-Barbara/Document/service&parts.pdf[/url].
> TIA
> CP
>[/color]
Old 11-25-2005, 10:32 AM   #5 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
Re: Timing Belt
On Fri, 25 Nov 2005 09:22:52 -0500, Wolfgang wrote:
[color=blue]
> ~$200 on a 4 cyl (offer is still available but might have gone up $10-20).[/color]
Yeah, a LOT of people recommend replacing the water pump when you do the
timing belt.
However, on most of the models I have or have owned, the water pump has
NOTHING to do with the timing belt. At all.
The Toys I know about (that I have bought new) are or have been on their
original water pumps for over 200,000 miles, except my '80 Corolla SR-5
that needed a new pump at 180,000.
The pump will let you know when it needs replacement. They sound like hell
when they're about to let go.
[color=blue]
> news:20702-438657A6-257@storefull-3273.bay.webtv.net...[color=green]
>> TIA
>> CP
>>[/color][/color]
If a Vegetarian eats vegetables, what does a humanitarian eat?
Old 11-25-2005, 11:39 AM   #6 (permalink)
Philip
Guest
Posts: n/a
View Philip's Photo Gallery
Re: Timing Belt
"Hachiroku" <Trueno@ae86.GTS> wrote in message
news:pan.2005.11.25.16.33.26.11464@ae86.GTS...[color=blue]
>[color=green]
>> it
>> replaced
>> $10-20).[/color]
> timing belt.
>[/color]
IT is disingenuous to state water pumps usually fail with lots of noise.
Consider WHY pump bearings fail in the first place. They fail because of
lubricant loss. Why does this happen? Typically, the coolant weep hole on
the underside of the pump becomes CLOGGED with antifreeze that has leaked
past the mechanical seal or between the seal and the pump housing and
external dirt. Now you've got a leak that cannot drain so ... this escaped
coolant works its way into the two bearings. Guess what happens next?
When the water pump failed on the 90 Prizm at 160k miles, there was no
noise. The FIRST clue was a small puddle of coolant on the floor in the
morning. The first replacement water pump failed the same way. A small
puddle of coolant on the floor in the morning. NEITHER pump was allowed to
progress to the point of bearing failure ... which is what you describe.
Most often, replacing the cam belt involves as much labor and going in for
only the water pump. But if the dealer can talk you into replacing the pump
"only if we find it failing" ... are banking on a failure in the near future
than will get you back in for only the pump which ... will make them more
money than had you replaced both cam belt and pump when the car was in for
only the cam belt.
If I owned an engine with cam belts and a buried water pump, and the belt(s)
were ripe for replacement, there is no way I'm not replacing the water pump
too since everything is apart just for the belt(s).
- Philip
Old 11-25-2005, 08:19 PM   #7 (permalink)
Hachiroku
Guest
Posts: n/a
Re: Timing Belt
On Fri, 25 Nov 2005 17:39:39 +0000, Philip wrote:
[color=blue]
> news:pan.2005.11.25.16.33.26.11464@ae86.GTS...[color=green]
>>[color=darkred]
>>> it
>>> replaced
>>> $10-20).[/color]
>> timing belt.
>>[/color]
> only the cam belt.
> too since everything is apart just for the belt(s).[/color]
Well, all my 'yotas have the water pump right where I can get to them.
Old 11-26-2005, 08:41 AM   #8 (permalink)
Philip
Guest
Posts: n/a
Re: Timing Belt
news:pan.2005.11.26.02.20.28.373@ae86.GTS...[color=blue]
>[color=green]
>> news:pan.2005.11.25.16.33.26.11464@ae86.GTS...[color=darkred]
>>>> said
>>>> it
>>>> replaced
>>>> repair
>>>> $10-20).
>>> timing belt.
>>> hell
>>>[/color]
>> on
>> escaped
>> to
>> for
>> pump
>> future
>> for
>> only the cam belt.
>> belt(s)
>> pump
> --[/color]
What's the latest or last Toyota you bought? Does it have pushrods or rear
wheel drive? LOL
- Philip
Old 11-26-2005, 09:15 AM   #9 (permalink)
Hachiroku
Guest
Posts: n/a
Re: Timing Belt
On Sat, 26 Nov 2005 14:41:16 +0000, Philip wrote:
[color=blue]
> news:pan.2005.11.26.02.20.28.373@ae86.GTS...[color=green]
>>[color=darkred]
>>>>> said
>>>>> it
>>>>> replaced
>>>>> repair
>>>>> $10-20).
>>>> timing belt.
>>>> hell
>>> on
>>> escaped
>>> to
>>> for
>>> pump
>>> future
>>> for
>>> only the cam belt.
>>> belt(s)
>>> pump
>> --[/color]
> wheel drive? LOL[/color]
The LATEST was the '95 Tercel. We were going to do the water pump...oh,
wait, we did...after I sold the car. But, it was hanging right out there
in the open, driven by it's own little belt.
All the rest are RWD. That'll give you a hint...
I've spent a great deal of money on Whiskey, Women and Fast Cars
The rest I've squandered.
Old 12-06-2005, 05:41 PM   #10 (permalink)
Charles Pisano
Guest
Posts: n/a
Re: Timing Belt
I was quoted a price of 199 to do the belt. They said they would LOOK at
the pump but not replace it unless needed. They said the hoses wont need
replacing either. I was also quoted 119 for a 3 day weekend rental on a
sienna. Those prices are with the discounts. 50 off of the belt job and
a service department credit on the rental.
So, not bad. I get to try out the Sienna up to 500 miles and got a good
deal on the work. I will probably insist on them replacing the water
pump. I can do the hoses later.
How hard is the WP on THIS MODEL?
tanks
CP
Old 12-06-2005, 06:05 PM   #11 (permalink)
Gary L. Burnore
Guest
Posts: n/a
View Gary L. Burnore's Photo Gallery
Re: Timing Belt
On Tue, 6 Dec 2005 18:41:38 -0500, [email]pisanochas@webtv.net[/email] (Charles
Pisano) wrote:
[color=blue]
>a service department credit on the rental.[/color]
Were I you, I'd insist on and pay the extra for replacement of the
waterpump.
[color=blue]
>How hard is the WP on THIS MODEL?[/color]
Not hard once you take off the same stuff you need to remove to do the
timing belt. You can't "look" at a water pump and determine that it's
ok. Replace it.
[color=blue]
>tanks
>CP[/color]
gburnore at DataBasix dot Com
How you look depends on where you go.
Gary L. Burnore | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
Official .sig, Accept no substitutes. | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
| ÝÛ 0 1 7 2 3 / Ý³Þ 3 7 4 9 3 0 Û³
Black Helicopter Repair Services, Ltd.| Official Proof of Purchase
Old 12-06-2005, 06:09 PM   #12 (permalink)
Ray O
Guest
Posts: n/a
Re: Timing Belt
news:16116-439621B2-483@storefull-3278.bay.webtv.net...[color=blue]
> tanks
> CP
>[/color]
What model?
Ray O
Old 12-06-2005, 08:50 PM   #13 (permalink)
Charles Pisano
Guest
Posts: n/a
Re: Timing Belt-2001 Toyota Camry 4 cyl.
Sorry. didn't realize OP was gone.
Looking forward to trying the sienna and seeing what I get out of a tank
of gas. \
They also said the price of the rental would be taken off of the price
of a Sienna if I BUY one. That isn't a concession at all really since
the price is so arbitrary anyway.. But I guess for the uninitiated it
can seem to be.
CP
Old 12-06-2005, 08:52 PM   #14 (permalink)
Charles Pisano
Guest
Posts: n/a
Re: Timing Belt
Also he was talking about cam shaft seals and crank seals? I think is
what he said he was going to inspect. He said they go alot on that
vehicle. True?
CP
Old 12-06-2005, 11:05 PM   #15 (permalink)
Ray O
Guest
Posts: n/a
Re: Timing Belt
news:17057-43964E7A-2317@storefull-3274.bay.webtv.net...[color=blue]
> vehicle. True?
> CP
>[/color]
What vehicle? I'm not aware of any Toyota with a high failure rate on cam
shaft and crank shaft seals.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
