Battery hooked up wrong - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2005, 10:11 PM   #1 (permalink)
tc93610
Guest
Posts: n/a
View tc93610's Photo Gallery
Some one hooked up my battery backwards and it started smoking. Now the
car won't start. What did they burn out?. Thanks.
Old 11-25-2005, 10:26 PM   #2 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
Re: Battery hooked up wrong
On Fri, 25 Nov 2005 23:11:53 -0500, tc93610 wrote:
[color=blue]
> car won't start. What did they burn out?. Thanks.[/color]
If you're lucky, just the battery.
If you're just a little unlucky, the Fusible Links, generally mounted in
the fuse block under the hood.
If you're totally screwed, they took out the voltage regulator, which is
usually attached to the alternator. There are replacement regulators
available.
Unfortunately, you didn't say what year/model, so these are
generalizations...
I've spent a great deal of money on Whiskey, Women and Fast Cars
The rest I've squandered.
Old 11-25-2005, 10:35 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"tc93610" <poochy2@nospam.sbcglobal.net> wrote in message
news:49c6ee2821105c416ad316ac7e0a6662@localhost.talkaboutautos.com...[color=blue]
>[/color]
You are very lucky that the battery did not burst.
Check the 100 Amp main fuses in the engine compartment and the fusible
links.
Ray O
correct the return address punctuation to reply
Old 11-25-2005, 11:46 PM   #4 (permalink)
Gary L. Burnore
Guest
Posts: n/a
View Gary L. Burnore's Photo Gallery
On Sat, 26 Nov 2005 04:26:18 GMT, Hachiroku <Trueno@ae86.GTS> wrote:
[color=blue]
>[color=green]
>available.
>generalizations...[/color]
Right. If it's a newer model (with a computer) he could well have
lost it. If the smoking was from wiring rather than the battery, at
minimum he's looking at replacing the wiring harness or parts of it.
I especially like the "someone" and "they". Heh.
gburnore at DataBasix dot Com
How you look depends on where you go.
Gary L. Burnore | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
Official .sig, Accept no substitutes. | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
| ÝÛ 0 1 7 2 3 / Ý³Þ 3 7 4 9 3 0 Û³
Black Helicopter Repair Services, Ltd.| Official Proof of Purchase
Old 11-26-2005, 12:12 AM   #5 (permalink)
Mark A
Guest
Posts: n/a
View Mark A's Photo Gallery
"Gary L. Burnore" <gburnore@databasix.com> wrote in message
news:dm8sqv$lf2$1@blackhelicopter.databasix.com...[color=blue]
> --[/color]
Usually it is a "friend".
Old 11-26-2005, 02:33 PM   #6 (permalink)
Jim Tiberio
Guest
Posts: n/a
View Jim Tiberio's Photo Gallery
"Ray O" <rokigawa@tristarassociatesDOT.com> wrote in message
news:42457$4387e620$180fead6$11233@msgid.meganewsservers.com...[color=blue]
> news:49c6ee2821105c416ad316ac7e0a6662@localhost.talkaboutautos.com...[color=green]
>>[/color]
> links.
> --[/color]
That did the trick for me when I hit the wrong terminals with my jumper
cables, quick and cheap fix. I don't know if kooking up the battery wrong
is worse though.
Old 11-28-2005, 08:28 AM   #7 (permalink)
Art
Guest
Posts: n/a
View Art's Photo Gallery
Actually on older Toyota's it is easy since colors reversed from most
American cars. Been there and done that with no damage on an 83. On an 87
a friend took out a fusible link.
"Hachiroku" <Trueno@ae86.GTS> wrote in message
news:pan.2005.11.26.04.27.27.861519@ae86.GTS...[color=blue]
>[color=green]
> available.
> generalizations...
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
