Toyota Corolla 2002: Noise when car is started, in drive, and in reverse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2005, 01:30 PM   #1 (permalink)
Jessica
Guest
Posts: n/a
View Jessica's Photo Gallery
I have a 2002 Toyota Corolla LE with about 50 some thousand miles on it. I am
in the military so I travel a lot. I got the car used with 26 thousand miles
on it and it sounded fine then. I do oil changes on it when needed, make sure
my other fluid levels are full, make sure the tires have enough air, and I
have changed the brakes once so far. Just last winter was when the noise in
the car started. It is like a loud grumbling noise when first started, put
into reverse, and put into drive. After the car has warmed up the sound is
quieter but still there, which wasn't like that before. I can't seem to
figure out what would be causing the noise besides maybe the belts or the air
pump. Does anyone have any ideas? I'm at a loss! Thanks for your help!
Old 11-29-2005, 01:43 PM   #2 (permalink)
Jessica
Guest
Posts: n/a
Re: Toyota Corolla 2002: Noise when car is started, in drive, and in reverse
Jessica wrote:[color=blue]
>figure out what would be causing the noise besides maybe the belts. Does anyone have any ideas? I'm at a loss! Thanks for your help![/color]
Old 11-29-2005, 02:24 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Jessica" <u16217@uwe> wrote in message news:5818d25e8c3c9@uwe...[color=blue]
>am
> miles
> sure
> in
> air
> pump. Does anyone have any ideas? I'm at a loss! Thanks for your help![/color]
Several things can cause grumbling noises.
Check your coolant level in the radiator and in the overflow reservoir.
Check the fluid level in the power steering reservoir.
Check the oil level and color in your transmission.
Ray O
correct the return address punctuation to reply
Old 11-29-2005, 02:52 PM   #4 (permalink)
Mark
Guest
Posts: n/a
View Mark's Photo Gallery
Could you have a hole in the muffler? Is it louder outside the car
than inside?
Old 11-29-2005, 03:09 PM   #5 (permalink)
Jessica
Guest
Posts: n/a
All of the fluid levels are fine in the car. The noise is coming from the
engine but more so on the passenger side of the car. It doesn't seem to be
anything serious but I would like to fix the problem to have a quiet car
again. Thanks!
Old 11-29-2005, 03:36 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
"Jessica" <u16217@uwe> wrote in message news:5819b0ddb2010@uwe...[color=blue]
> again. Thanks![/color]
How many miles are on the car?
Ray O
Old 11-30-2005, 06:47 AM   #7 (permalink)
Jessica via CarKB.com
Guest
Posts: n/a
View Jessica via CarKB.com's Photo Gallery
Ray O wrote:[color=blue][color=green]
>How many miles are on the car?[/color]
50 some thousand, I'd say I'm in the mid-50's.
Message posted via [url]http://www.carkb.com[/url]
Old 11-30-2005, 11:19 AM   #8 (permalink)
Ray O
Guest
Posts: n/a
"Jessica via CarKB.com" <u16217@uwe> wrote in message
news:5821e047bef24@uwe...[color=blue]
> Ray O wrote:[color=green][color=darkred]
>>> the
>>> be
> Message posted via [url]http://www.carkb.com[/url][/color]
Have the timing belt checked. It may be getting loose.
Ray O
Old 11-30-2005, 11:40 AM   #9 (permalink)
Guest
Posts: n/a
Ray O wrote:[color=blue][color=green][color=darkred]
>>>> the[/color][/color]
>[quoted text clipped - 6 lines][color=green]
>> 50 some thousand, I'd say I'm in the mid-50's.[/color]
>Have the timing belt checked. It may be getting loose.[/color]
Ok thanks! I'll keep it posted on here!
Message posted via CarKB.com
[url]http://www.carkb.com/Uwe/Forums.aspx/toyota/200511/1[/url]
Old 11-30-2005, 04:16 PM   #10 (permalink)
Ray O
Guest
Posts: n/a
news:58246fe7c0240@uwe...[color=blue]
>>>>> the[/color]
>>[quoted text clipped - 6 lines][color=darkred]
> [url]http://www.carkb.com/Uwe/Forums.aspx/toyota/200511/1[/url][/color]
You're welcome! The timing belt should be changed at 60,000 miles any way.
Ray O
Old 11-30-2005, 04:51 PM   #11 (permalink)
High Tech Misfit
Guest
Posts: n/a
View High Tech Misfit's Photo Gallery
> You're welcome! The timing belt should be changed at 60,000 miles any way.[/color]
I thought that version of Corolla had a timing chain, not a belt?
Old 11-30-2005, 05:28 PM   #12 (permalink)
Ray O
Guest
Posts: n/a
"High Tech Misfit" <me@privacy.net> wrote in message
news:pan.2005.11.30.21.51.01.762171@hightech.misfit...[color=blue]
>> way.[/color]
> I thought that version of Corolla had a timing chain, not a belt?[/color]
It sure does! To the original poster, forget the timing belt advice from
me.
Next steps:
Does the car make noise when moving or when sitting still? How about in
drive or reverse and sitting still? Does the noise change with engine speed
or with vehicle speed?
Can you hear the noise with the hood open? If so, from where? Behind the
timing cover?
Ray O
Old 11-30-2005, 06:40 PM   #13 (permalink)
Guest
Posts: n/a
>>>> Ok thanks! I'll keep it posted on here![/color][/color]
>[quoted text clipped - 3 lines][color=green]
>me.
>Next steps:
>timing cover?[/color]
The car makes noise mostly when still...in drive, idle, and reverse the most
but not when in netural. Once I get driving down the road it still makes the
noise for a while and quiets down after the car gets warmer but is still
making the noise. It sounds like a grumbling noise when sitting in the car
but when I have the hood open it sounds like a vibration. When I go faster,
vehicle speed, the noise is hardly there at all. With the engine speed, just
sitting still, the sounds fades away a little bit as well. The noise seems to
be coming from the belt/alternator area but I can't seem to pin point it.
Old 11-30-2005, 07:06 PM   #14 (permalink)
High Tech Misfit
Guest
Posts: n/a
Jessica via CarKB.com wrote:
[color=blue]
> be coming from the belt/alternator area but I can't seem to pin point it.[/color]
I'm not 100% sure, but it's a possibility...
Have someone listen from outside the car especially when you have it in
reverse or when idling. If it sounds like a metallic rattle, the problem
is a loose heat shield. I had similar symptoms with my Honda Accord not
too long ago. The rattle did sound like a grumbling sound from inside.
Old 11-30-2005, 09:53 PM   #15 (permalink)
Ray O
Guest
Posts: n/a
news:58281aae760bc@uwe...[color=blue]
>>[quoted text clipped - 3 lines][color=darkred]
>>me.
>>Next steps:
>>speed
> most
> the
> faster,
> just
> to
Some late model Corollas had drivetrain noises that concerned some people.
The best way to tell if that is the noise is to take it to a dealership and
have someone there listen to it.
If the noise is coming from under the timing cover then a loose timing chain
tensioner is a possibility.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
