93 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2005, 02:09 PM   #1 (permalink)
baqi
Guest
Posts: n/a
View baqi's Photo Gallery
93 Corolla
I have a 1993 Corolla and I am having problems with the heat on the inside
of the car. The radiator seems fine, there appears to be no leak and the
hoses don't seem tight. I was thinking that it may be the thermostat but
that did not solve the problem. Does anyone know anything else I can check
before I take it to the dealer?
Old 11-29-2005, 02:22 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 93 Corolla
"baqi" <baqicherry@yahoo.com> wrote in message
news:1b246b8be6eb71a5573890967c3e8214@localhost.talkaboutautos.com...[color=blue]
>[/color]
It would be helpful if you provided a little more information, like what
kind of problems you are having with the heat inside the car. It there too
little heat? No heat? Too much heat?
When you say that the hoses don't seem tight, does that mean that they are
loose?
You should check the heater control valve in the engine compartment to see
if it is moving when you move the temperature control on the dash.
Ray O
correct the return address punctuation to reply
Old 11-29-2005, 02:22 PM   #3 (permalink)
njmodi
Guest
Posts: n/a
View njmodi's Photo Gallery
Re: 93 Corolla
Whats the problem? No heat inside via the vents/HVAC?
Old 11-30-2005, 07:42 AM   #4 (permalink)
Stewart DIBBS
Guest
Posts: n/a
View Stewart DIBBS's Photo Gallery
Re: 93 Corolla
> before I take it to the dealer?[/color]
For a 93, try your local garage first. You'll pay up to double the labour
rate for the same service from a dealer.
Stewart DIBBS
Old 11-30-2005, 12:13 PM   #5 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
Re: 93 Corolla
On Tue, 29 Nov 2005 14:09:16 -0500, "baqi" <baqicherry@yahoo.com>
wrote:
[color=blue]
All simple stuff! Check to see if the heater valve is letting hot
water through the heater core - do the heater hoses get hot?
Does the heater blower fan run? Try all the speed settings, if the
speed control resistor pack has burned out (cheap part at the dealer)
High speed will be all you have. This can also be a blown fuse, worn
out fan motor, bad switch in the heater control cluster.
A known fault in some models is a bad solder joint to the switch in
the heater control cluster. If you can get the fan to come on for a
few seconds by wiggling the switch, that's the problem - pop the
control cluster out and get a soldering iron.
Do the damper doors switch to the right positions to send heat out
the floor ducts? On most Toyotas they are cable operated, others have
vacuum motors or electric motors. Grab a flashlight, lay on your back
in the passenger-side doorway and stick your head in the passenger
footwell as someone operates the control levers, you'll see and hear
the damper doors operating.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
BB code is Off
Smilies are Off
[IMG] code is Off
