when the battery is said fully charged? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2005, 01:40 PM   #1 (permalink)
wenmang@yahoo.com
Guest
Posts: n/a
View wenmang@yahoo.com's Photo Gallery
Hi,
I am wondering when the battery is said fully charged? I like to
measure the voltage of the battery to see whether it need to be
replaced(6 yrs old), thanks.
wm
Old 11-30-2005, 04:20 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: when the battery is said fully charged?
<wenmang@yahoo.com> wrote in message
news:1133376008.733801.155460@f14g2000cwb.googlegroups.com...[color=blue]
> Hi,
> wm
>[/color]
A fully charged battery will be somewhere between 12 and 14.4 volts.
Voltage alone is not an indicator of whether the battery needs replacement
or not.
If you live in a very hot or cold climate and the battery is 6 years old,
I'd think about getting it replaced soon.
Ray O
correct the return address punctuation to reply
Old 11-30-2005, 04:36 PM   #3 (permalink)
wenmang@yahoo.com
Guest
Posts: n/a
Thanks Ray. The thing that I cannot determine is how could you tell
whether a battery is full charged or not even if its voltage is below
12V? How long I need to drive on highway in order to have it full
charged?
thanks.
Old 11-30-2005, 04:36 PM   #4 (permalink)
wenmang@yahoo.com
Guest
Posts: n/a
charged?
thanks.
Old 11-30-2005, 04:55 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
news:1133386576.989816.137250@z14g2000cwz.googlegroups.com...[color=blue]
> charged?
> thanks.[/color]
If a battery is not at 12 volts then it is not fully charged.
If a battery is at 12 to 14.4 volts, then it is fully charged by it may not
have enough reserve capacity to get the car started on a cold day.
How long you need to drive on the highway to get it fully charged depends on
several factors. One, the charge state of the battery, the amperage output
of the alternator, and how fast you're driving. If everything is in good
working order, you should be able to fully charge a battery on the highway
in 10 or 15 minutes.
Ray O
Old 11-30-2005, 04:56 PM   #6 (permalink)
TheSnoMan
Guest
Posts: n/a
View TheSnoMan's Photo Gallery
Ray O wrote:[color=blue]
>[color=green]
>>Hi,
>>wm
>>[/color]
> or not.
> I'd think about getting it replaced soon.[/color]
Actually the voltage is a really good indicator of battery condition.
Fully charged at about 13.8 to 14.2 volts and a voltage check under a
load test will confirm its abilty to deliver the power properly.
Basically with a 150 amp load for 15 to 30 seconds, the voltage should
stay well above 11 volts the whole time. It it drops steadily during the
test without leveling out after a few seconds or so, the battery is
getting soft or not properly charged.
[url]www.thesnoman.com[/url]
Old 11-30-2005, 06:03 PM   #7 (permalink)
Ray O
Guest
Posts: n/a
"TheSnoMan" <admin@snoman.com> wrote in message
news:Iepjf.10881$aA2.9457@newsread2.news.atl.earthlink.net...[color=blue]
> Ray O wrote:[color=green]
>>[color=darkred]
>>>Hi,
>>>wm
>>>[/color]
>> replacement or not.
> . Fully charged at about 13.8 to 14.2 volts and a voltage check under a
> load test will confirm its abilty to deliver the power properly. Basically
> with a 150 amp load for 15 to 30 seconds, the voltage should stay well
> above 11 volts the whole time. It it drops steadily during the test
> without leveling out after a few seconds or so, the battery is getting
> [url]www.thesnoman.com[/url][/color]
I said that voltage alone is not an indicator of whether the battery needs
replacement or not because I'm pretty sure that the OP did not have a
battery load tester.
You said "Actually the voltage is a really good indicator of battery
condition" implying that I was incorrect but then you go on and add that the
voltage needs to be measured under a load.
I don't mind being corrected if I'm wrong although it does bug me to be
correct and have someone who agrees with me claim I'm wrong ;-)
Ray O
Old 11-30-2005, 09:50 PM   #8 (permalink)
do_not_spam_me@my-deja.com
Guest
Posts: n/a
View do_not_spam_me@my-deja.com's Photo Gallery
[email]wenmang@yahoo.com[/email] wrote:
[color=blue]
> I am wondering when the battery is said fully charged?[/color]
The [url]www.batteryfaq.org[/url] should have the information, but here is state
of charge verses voltage information:
12.6V >75% charged
12.2V 50%
12.0V 25%
11.7V 0%
Measurements taken only a few hours after the engine has been turned
off will read higher because of surface charge, so when in doubt turn
on the headlights for 30 seconds and then turn them off before
measuring.
The battery should also be tested under load by turning on the high
beams, ventilation fan on high, and rear window defroster but not
running the engine. The voltage should remain at 9.5V or higher for
at least 30 seconds.
The final charge rate can be a better indicator of battery condition
but requires use of an automatic charger with an ammeter. A final rate
of less than 1A after several hours indicates good condition, but a
battery over 5 years old can still fail suddenly. Ammeters found on
chargers aren't highly accurate, but a final meter reading of over 2A
after overnight charging likely predicts failure within 6 months.
BB code is Off
Smilies are Off
[IMG] code is Off
