Re: 91 Camry... How do you remove plug wires from distributor??
"Al Kondo" <alkon@hal-pc.org> wrote in message
news:438f6654.109697764@news.hal-pc.org...[color=blue]
>I am working on my old 91 Camry LE. It has been a great car (it has
> 188 k miles) and I have worked on most of its problems during the
> years. I am working on diagnosing what appears to be an ignition
> system problem and I ran into a problem that has bugged me for years.
> The spark plugs attach to the distributor with a plastic cap. I the
> past I have actually broken these caps in my effort to get the plug
> off the distributor. Last year, I replaced the plugs with a new set
> of OEM plugs. Therefore, I am back to trying to get these plugs off
> the distributor again. Is there a trick that will get them off
> without destroying the plastic caps??
> Thanks, Al Kondo[/color]
Al,
Don't the spark plugs attach to ignition wires, which are attached to the
distributor cap?
Are you talking about difficulty removing the spark plugs from the ignition
wires or are you talking about removing the ignition wires from the
distributor cap? I don't recall which models and years, but some have the
cap and wires as an assembly where the wires do not disconnect from the cap.
Ray O
correct the return address punctuation to reply
