Re: 93 Corolla cruise control stops working
"Bob Griffin" <bobgrif61@earthlink.net> wrote in message
news:lsOkf.9342$N45.7857@newsread1.news.atl.earthlink.net...[color=blue]
> the cruise control will often stop working for no apparent reason. it
> will work fine for many miles, then suddenly disengage. sometimes i can
> reset it right away. other times i must restart the vehicle in order to
> reset the cruise control.
> thanks in advance for any suggestions!
> Bob
> 93 corolla dx automatic[/color]
Assuming that it has a factory cruise control, does the resume feature work?
If so, check the parking brake switch and service brake pedal brake light
switch adjustment. If you have a manual transmission, check the adjustment
on the clutch pedal switch. Check for a wire shorted to ground on your
brake lights.
If the resume feature does not work, make sure the wire harness under the
steering column is not loose.
Ray O
correct the return address punctuation to reply
