Re: 91 celica electrical problem
"Ray O" <rokigawa@tristarassociatesDOT.com> wrote:
[color=blue]
>"specialpatrolgroup" <noemail@noemail.com> wrote in message
>news:d1ckp1tui4vcvo0rcn2o0lerpifik3kd7o@4ax.com...[color=green]
>>I have a 91 celica GT 2.2L and am having problems some electrical
>> problems, I'm not sure if they're related. I think they are. The
>> problems I'm having are the dome light doesn't come on when the door
>> is open but it works when set to the on position, but when it is set
>> to turn on when the door is open it doesn't work. Also, the warning
>> buzzer for lights left on without the key in the ignition doesn't
>> work. I have left the lights on several times and drained the
>> battery. also there is a light around the ignition that should come
>> on when the door is opened and stays on for a while so you can see
>> where to insert the key. This light is not working either. I have a
>> Chilton book for Toyota Celica's from 86-93 but can't find any clues
>> from the schematics in there. Does anyone have a clue on this
>> one?????
>> any help is greatly appreciated!
>> SED
>>[/color]
>Most likely, the door switch is stuck in the off position. Look for the
>switch in the door frame, usually near the bottom corner. Carefully peel
>back the rubber cover, spray some WD-40 and get the plunger loose, working
>it in and out a few times and then replace the cover.[/color]
Almost for certain this is it....some vehicles don't even have a
rubber protector over the plunger...as Ray says spray it and I'll
add take one of those little jeweler's screwdrivers and see if
you can pry the plunger out (it'll be stuck 'into' the hole),
take care not to damage the plunger. The ones I've seen are made
of plastic or nylon.
-Gord.
(use gordon in email)
