Re: 2004 Toyota Matrix engine rattle
In article <qvbsp1d6v88gukcphd1n1d1m5ch64jgv3g@4ax.com>,
Gord Beaman <gord@islandtelecom.com> wrote:
[color=blue]
> Sean Elkins <sean_elkins@yahoo.com> wrote:
>[color=green]
> >In article <1134415953.183788.247690@f14g2000cwb.googlegroups.com>,
> > "Rick" <rickie_b_schneegold@keane.com> wrote:
> >[color=darkred]
> >> 2004 Matrix 5 speed, approx 33K miles. Recently have been getting a
> >> rattling which appears to be coming from the engine. Sounds somewhat
> >> like bad gas, low octane. Took it to the dealer and they said I had a
> >> bad tank of gas. After a couple of new tanks the noise is still
> >> there.
> >> Sounds as if its running like a deisel. Noise more noticeable at low
> >> speeds.
> >> Saw the posting about oil gelling. Not sure if this is the cause or
> >> not. Maybe I'll try some higher octance gas to see if it goes away.
> >> Last oil change about 2k miles ago. Change it every 3500 miles.
> >> Any ideas?
> >> Rick[/color]
> >Are you sure it's really engine noise? I hear the same niose in my
> >Matrix, but it doesn't go away when I shift into neutral and let the
> >engine idle down. I only hear it at highway speeds.
> >I'm pretty sure that what I'm hearing are the plastic wind panels below
> >the engine rattling because the plastic fasteners are loose.[/color]
> If it IS 'spark knock or pinging' (detonation) then you'll only
> hear it when the engine is 'pulling hard', (and especially at
> high RPM)...let off on the accelerator and it'll stop.[/color]
That was the point I was trying to make--I hear it regardless of what
the engine is doing. That's what makes me think my particular noise
isn't coming from the engine.
Now the noise I'm hearing from my wife's old Corolla on the other
hand.... I think that's piston slap that happens until it warms up and
the pistons/rings expand. The little fellas have just gone up and down
in those holes so many times they don't fit quite like they used to.
The OP said his noise was more noticable at low speeds, which I missed
on the first reading-- that doesn't sound like road/wind noise. I think
your comment about if it's happening under load is a good one to help
him diagnose what's probably going on.
