Intermitant starting problem (2002 Tundra) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2005, 02:57 PM   #1 (permalink)
jeff7091
Guest
Posts: n/a
View jeff7091's Photo Gallery
Occasionally, I have a problem where I hear a repeated clicking noise
when I
go to start the engine. Not a single click. And it isn't the same sound
as when you
try to start an engine that is already started, either :-)
After letting the car sit for a bit (anywhere from 1/2min to 10 min), I
can start it
as normal.
My guess is that the solenoid is pushing the gear to the flywheel (or
maybe just not
far enough), and that the starter gear isn't engaging with the
flywheel. Battery
voltage seem fine, and this happens only a coulpe of times per year.
Maddening!
Any ideas? Experiences?
Thanks,
Jeff
Old 12-12-2005, 03:23 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Intermitant starting problem (2002 Tundra)
"jeff7091" <jeff.enderwick@gmail.com> wrote in message
news:1134421042.145201.76140@g47g2000cwa.googlegroups.com...[color=blue]
> when I
> as when you
> can start it
> as normal.
> maybe just not
> flywheel. Battery
> Maddening!
> Thanks,
> Jeff
>[/color]
How do you know that the battery voltage seems fine? Did you measure with a
meter?
Check for loose connections at the battery posts, ground, and where the
positive cable attaches to the starter.
Ray O
correct the return address punctuation to reply
BB code is Off
Smilies are Off
[IMG] code is Off
