Re: 99 Corolla stoplight problem
"mwebsurfer" <mwebsurfer@verizon.net> wrote in message
news:XZJnf.16357$hB6.1848@trnddc05...[color=blue]
> Ray O wrote:[color=green]
>> news:Nvlnf.37077$Y7.5738@trnddc02...
>>[color=darkred]
>>>I have a 99 corolla that has a stoplight problem. The left light
>>>isn't working although the bulb is good. I can't do much tracing
>>>but there is no power to the socket. Anyone have any experience
>>>with the wiring? Is there a fuse for each bulb or a wiring diagram
>>>available? Any help will be appreciated.[/color]
>> How do you know that the bulb is good? Did you try a known good bulb,
>> like from the other side?
>> How do you know that there is no power to the socket? Did you test with
>> a ground other than the socket's ground or did you test between the
>> positive and negative terminals in the socket? If you checked between
>> the positive and negative terminals in the socket, it is possible that
>> you have no ground and there is power coming to the socket. The most
>> common reason of rear light problems is a loose ground somewhere back
>> there. Check all ground wires to make sure they make good contact with
>> ground.[/color]
> I checked the bulb across the battery with jumpers and it lit.
> I checked the socket with a vometer to the chassis ground. No juice.[/color]
When I read your original post, I missed the question about whether there is
a fuse for each bulb, and the answer is no - left and right side share one
power source. Since it is a tail light/brake light socket, I'm assuming you
checked both filaments in the bulb and both worked. Assuming that the turn
signal bulb is a separate bulb, then you should only have to trace back to
where the harness splits left and right. If that doesn't work, then wire a
parallel circuit from the right side.
Ray O
correct the return address punctuation to reply
