1988 Toyota Corolla Hatch Back - losing gas - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2005, 05:31 PM   #1 (permalink)
d.tesch@comcast.net
Guest
Posts: n/a
View d.tesch@comcast.net's Photo Gallery
I bought this car brand new back in 1988 and I still love driving it.
I've only driven in around town so it only has 120,000 mile on it, but
it is starting to having a few problems. Just recently, I've noticed
that it is going through gas at an accelerated rate. It usually gets
about 25 miles per gallon, but over the past two weeks it is only
getting 10 miles to the gallon. What might be causing such a sudden
change. I can't tell if there is a leak and know no one is syphoning
gas. I have a great mechanic, but I just don't have a lot time and
money right now to go see him...
Old 12-12-2005, 05:40 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 1988 Toyota Corolla Hatch Back - losing gas
<d.tesch@comcast.net> wrote in message
news:1134430266.805966.239960@g49g2000cwa.googlegroups.com...[color=blue]
>[/color]
Several things can make the car go through gas.
- A leak somewhere in the fuel system, including the filler neck, tank
itself, fuel lines, or a leaking carb/injector.
- Transmission problem - choosing incorrect gear, torque converter/clutch
slippage
- Carb/fuel injection problem with the engine running rich
- Dragging brakes
- Siphoning - how do you know that nobody is siphoning gas?
Ray O
correct the return address punctuation to reply
Old 12-12-2005, 05:48 PM   #3 (permalink)
tomcas
Guest
Posts: n/a
View tomcas's Photo Gallery
[email]d.tesch@comcast.net[/email] wrote:[color=blue]
>[/color]
Check the filler neck for leaks. My 86 rotten out after only 80k miles.
It began by leaking gas when the tank was full and the car was parked on
an incline with the front higher then the rear. If this is your problem
then duplicating these conditions should easily show a leak.
Old 12-13-2005, 04:45 PM   #4 (permalink)
someone@somewhere.org
Guest
Posts: n/a
View someone@somewhere.org's Photo Gallery
[email]d.tesch@comcast.net[/email] <d.tesch@comcast.net> wrote:[color=blue]
> money right now to go see him...[/color]
Did it recently get cold where you live? Does your thermostat warm up
as fast as it used to? Have you ever replaced the thermostat?
Old 12-14-2005, 07:01 AM   #5 (permalink)
RG
Guest
Posts: n/a
View RG's Photo Gallery
>[/color]
Check your oil level. Couldn't the fuel pump be a source for leaking into
the crank case?
Old 12-14-2005, 11:53 AM   #6 (permalink)
Ray O
Guest
Posts: n/a
"RG" <rguy@cox.net> wrote in message news:1JUnf.80258$2k5.4393@dukeread09...[color=blue]
> news:1134430266.805966.239960@g49g2000cwa.googlegroups.com...[color=green]
>>[/color]
> the crank case?[/color]
A mechanical fuel pump could potentially leak fuel into the crank case, an
electric fuel pump is not likely to do so.
Ray O
Old 12-30-2005, 09:36 PM   #7 (permalink)
d.tesch@comcast.net
Guest
Posts: n/a
Thanks for all the help everyone. I found out that there was a leak or
tear in the manifold which was causing the gas leak. I had it fixed and
the car is running great and getting great gas mileage.
BB code is Off
Smilies are Off
[IMG] code is Off
