1989 P/U 22r engine hesitation/bucking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2005, 01:36 AM   #1 (permalink)
PJV267
Guest
Posts: n/a
View PJV267's Photo Gallery
Recently I have noticed that my p/u when cruising at 60 or above
begins to hesitate and bucking so bad that I have to shut the car off
let it sit and then drive again and then it does it again. Then if it
sits for a while it runs fine for a few days and does it again.: So
far I have noticed:
1) Has done it with full tank of gas and almost empty
2) Dry and in Rain
3) I only notive it on the highway (most of my driving)
4) I changed the wires and plugs
5) I’m not sure if it always does it when I’m cruising at then accel.
6) Seems it gets worst the more load I put on the engine.
7) I can put my foot down on the gas and the car just doesn’t move.
But when the car idles its fine.
8) The hesitation is like a bucking horse!!
Thanks for your help!
Posted using the [url]http://www.autoforumz.com[/url] interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: [url]http://www.autoforumz.com/1989-22r-engine-hesitation-bucking-ftopict148550.html[/url]
Visit Topic URL to contact author (reg. req'd). Report abuse: [url]http://www.autoforumz.com/eform.php?p=714178[/url]
Old 12-13-2005, 08:35 AM   #2 (permalink)
mrcheerful .
Guest
Posts: n/a
View mrcheerful        .'s Photo Gallery
Re: 1989 P/U 22r engine hesitation/bucking
"PJV267" <UseLinkToEmail@www.autoforumz.com> wrote in message
news:714178_4dbefd77c370cfd14d9f9c0c593487bc@autoforumz.com...[color=blue]
> far I have noticed:
> 2) Dry and in Rain
> 5) I'm not sure if it always does it when I'm cruising at then accel.
> 7) I can put my foot down on the gas and the car just doesn't move.
> Topic URL:
> [url]http://www.autoforumz.com/eform.php?p=714178[/url][/color]
fuel filter?
mrcheerful
Old 12-13-2005, 10:41 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
> far I have noticed:
> 2) Dry and in Rain
> Topic URL:
Some things to check for:
A crack in a vacuum switching valve - If you install a vacuum gauge on a
long hose and snake it in to the cab, you can see if vacuum is low when this
is happening.
You mentioned that you changed the wires and plugs. Assuming that you
changed them in hopes of curing the condition and it did not work, did you
check the cap and rotor? If you changed the plugs and high tension wires
and then the condition appeared, try using OEM ignition parts. Is the spark
advance working?
Is this a fuel injected or carbureted truck?
If carbureted, check fuel pump and while you are at it, check your oil for a
gas smell.
Ray O
correct the return address punctuation to reply
BB code is Off
Smilies are Off
[IMG] code is Off
