91 Camry.. Barely passed smog test... need suggestions to improve performance - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2005, 08:25 AM   #1 (permalink)
Al Kondo
Guest
Posts: n/a
View Al Kondo's Photo Gallery
I have a 91 Toyota Camry LE. It has automatic trans, 6 cylinders, and
180k miles. I have taken very good care of it since I purchased it in
92. I recently measured its compression and it read 170 - 175 psi on
all cylinders. I have faithfully changed oil every 3k miles since
its birth.
Last week, I had my car inspected for emissions (in Texas) and I
barely passed the HC portion of the test. Here are my pertinent
results:
Pollutant At High Speed At Low Speed
Standard Reading Standard Reading
HC (ppm) 123 58 128 127
CO (%) .69 .16 .71 .24
CO2 (%) 14.5 14.3
NOx (ppm) 878 437 970 449
As you can see from the results above, I just passed the HC at low
speed. I know that this usually means I have unburned fuel going out
of my exhaust. I don't know what would cause this, especially since
during the past year I have done the following:
1. Changed plugs (platinum, Bosch plugs)
2. Changed plug wires to Toyota OEM wires
3. Cleaned EGR valve
4. Changed PVC valve
5. Changed fuel filter
6. Changed distributor cap
Just before the emissions test, I changed oil and fuel filter. The
air filter has 6k miles on it.
I checked by ear and with propance gas any possible vacuum leaks at
the vacuum hose connections.
I want my vehicle to run as well as possible. I would appreciate some
suggestions on what I might do next.
Old 12-15-2005, 11:27 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 91 Camry.. Barely passed smog test... need suggestions to improve performance
"Al Kondo" <alkon@hal-pc.org> wrote in message
news:43a17c71.176358600@news.hal-pc.org...[color=blue]
> its birth.
> results:
> CO2 (%) 14.5 14.3
>[/color]
The O2 sensors in your exhaust manifold may be marginal. Also, next time
you install spark plugs, install OEM Desno plugs instead of the Bosch plugs.
Ray O
correct the return address punctuation to reply
Old 12-15-2005, 12:08 PM   #3 (permalink)
Philip
Guest
Posts: n/a
View Philip's Photo Gallery
"Ray O" <rokigawa@tristarassociatesDOT.com> wrote in message
news:15031$43a1a7c3$44a4a10d$19991@msgid.meganewsservers.com...[color=blue]
> news:43a17c71.176358600@news.hal-pc.org...[color=green]
>> its birth.
>> results:
>> CO2 (%) 14.5 14.3
>>[/color]
> plugs.
> Ray O[/color]
Additionally, there may be -nothing- wrong with the car. A marginal HC
reading can easily be a catalyst that was not fully up to operating
temperature ... and/or a catalyst with a lot of miles on it.
- Philip
Old 12-15-2005, 12:55 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
"Philip" <1chip-state1@earthlink.net> wrote in message
news:Fiiof.4956$3Z.307@newsread1.news.atl.earthlink.net...[color=blue]
> news:15031$43a1a7c3$44a4a10d$19991@msgid.meganewsservers.com...[color=green]
>> news:43a17c71.176358600@news.hal-pc.org...[color=darkred]
>>> its birth.
>>> results:
>>> CO2 (%) 14.5 14.3
>>>[/color]
>> plugs.
>> Ray O[/color]
> - Philip[/color]
Good point!
Ray O
Old 12-16-2005, 08:21 PM   #5 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
Echo comment on the Botched spark plugs! Changd the thermostate recently?
It will ensure you car gets to the correct operting temperature.
> its birth.
> results:
> CO2 (%) 14.5 14.3
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
