I have a 2004 Toyota Matrix that has 39,000 miles and the rear running
light won't come. This happens with the headlights on or off. The
bulbs are both good and the fuse is good. There is no current to the
running lights though the rear brake lights
and the both the real blinkers both work. Is there a relay involved in
these rear lights. All of the other lights work fine . Of course this
happend 3,000 miles after the warranty has expired. Any help on this
is appreciated.
On Thu, 22 Dec 2005 19:13:23 -0500, frank wrote:
[color=blue]
> is appreciated.
> Frank[/color]
Don't mean to imply aything here, but you *are* turning them on with the
switch, right?
The new Corollas have an 'auto on' feature that turns the headlights on
when it gets dark. Now, why they would ONLY turn the headlights on is
anybody's guess, but if you are relying on the auto on feature to turn all
the lights on, it doesn't. Only the headlights. Try hitting the switch and
see what happens (or, have you already...?)
I have tried the switch and every possible combination of dashboard
and light switch. Also received a warning from the police because they
were not on at night while all other lights were on.
[color=blue]
>[color=green]
>> is appreciated.
>> Frank[/color]
>switch, right?
>see what happens (or, have you already...?)[/color]
On Thu, 22 Dec 2005 21:49:44 -0500, frank wrote:
[color=blue]
> were not on at night while all other lights were on.[/color]
Oh, OK. Checked the fuses, both inside the car and under the hood?
Those Auto on headlights fool a lot of people. I guess the only indication
you get the lights aren't on is that the dash lights don't come on, but, I
was working at a Toy dealer this summer and they 'fixed' that, so you
could REALLY be fooled into thinking your lights were on.
The other thing I would be looking for was a pinched wire or a loose
connector. There are access panels in the back of the car, and IIRC the
wiring harness runs down the driver's side of the car, under the 'kickers'
in the bottom of the door openings. OR, you might have to lift the carpet.
Back in the 'good old days' Toyotas had crappy grounds for the taillights.
I had a '72 Corona MkII that the lights were out all the time on. They
used a chromed strip to ground the lights, and it worked loose frequently.
We replaced it with a couple pieces of wire and never had a problem again.
I don't THINK Toyota has gone back to this type of system...I hope...
[color=blue]
>[color=green]
>>[color=darkred]
>>> is appreciated.
>>> Frank[/color]
>>switch, right?
>>see what happens (or, have you already...?)[/color][/color]
Fuses are good, the dash lights work. I will trace the wires. It
looks like the taillights run on the same bundle of wires the brake
lights and the blinkers do which work so i will start from the fuse
panel under the steering wheel.
I did not check all the fuses, only the taillight fuse. Would it make
sense to check all the fuses?
Thanks.
[color=blue]
>[color=green]
>[color=green]
>>[color=darkred]
>>>> is appreciated.
>>>> Frank
>>>switch, right?
>>>see what happens (or, have you already...?)[/color][/color][/color]
On Fri, 23 Dec 2005 18:03:37 -0500, frank wrote:
[color=blue]
> sense to check all the fuses?[/color]
Did you check the parking break? If the parking break is on, the daytime
runners wont turn on. (bad switch?)
"Vash The Stampede" <Trigun@2am.cn> wrote in message
news:pan.2005.01.24.01.41.08.936275@2am.cn...[color=blue]
>[color=green]
> Yup!
> Have your Virtual Pet spayed/neutered![/color]
You were right, it was not the fuse called running light but the fuse
call instrument panel dash lights and tail lights. I did not look
well enough.
It is blowing the 15 amp fuses that is called for but will take a 25
amp though it has the new electronics or burning electronic smell a
little. Think that is a problem?
Thanks for your help.
[color=blue]
>[color=green]
>Yup![/color]
frank wrote:
[color=blue]
> well enough.
> little. Think that is a problem?[/color]
Get that 25-amp fuse out of there NOW! Never, ever use a fuse with a
higher amperage than what you should put in there. If it is blowing the
specified 15-amp fuses, then you have an electrical problem somewhere.
But using higher amperage fuses is NOT the solution.
In article <pan.2005.12.25.00.23.24.184042@hightech.misfit>, High Tech
Misfit <me@privacy.net> wrote:
[color=blue]
> frank wrote:
>[color=green]
> > well enough.
> But using higher amperage fuses is NOT the solution.[/color]
Please take HTM's advice to heart. Fuses have ratings for a reason.
That "burning electronic smell a little" is the prelude to a burning
electronic smell a lot. Fuses don't smell. If you smell burning at all,
the burning is in the circuitry the fuse would have been protecting if
it hadn't been replaced with a larger one.
Many houses burned in the old days when owners substituted a penny for
a screw-in fuse. Yes, the current flowed again -- right up to the point
where the circuitry overheated and set the place alite
Gosh, Frank... there aren't so many good folks on the net that we can
afford to risk one. :-)
On Sat, 24 Dec 2005 18:34:59 -0500, frank <frank@here.com> wrote:
[color=blue]
>well enough.
GET THAT OVERSIZED FUSE OUT OF THERE NOW!! You can burn up the main
wiring harnesses on the car and easily do $3,000 worth of damage -
more than the car is worth in many cases.
And if you get really unlucky, the car can catch on fire. Total
loss for sure. And the insurance will not cover it - comp and
collision does not cover electrical problems.
If it is popping that fuse, you have a short circuit somewhere that
must be diagnosed, located and fixed.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
