Re: 2002 Avalon lights flickering...
Bruce L. Bergman wrote:[color=blue]
> On Fri, 23 Dec 2005 09:07:41 -0600, Steve Henderson
> <shenderson_2@charter.net> wrote:
>[color=green]
>>I just replace my battery about 5 months ago... Yesterday, I noticed
>>that when I had any interior lights on, they kinda flicker... about 3
>>times a second... then noticed that the speedomoter lighting and ALSO
>>the headlights are doing it too. Here's the kicker... when I cut the
>>engine, the lights are all smooth - the flicker goes away. I checked the
>>battery connection and cleaned it - no joy. There are no warning lights
>>on in the dash. What's the most likely cause?
>>PLEASE don't tell me it's something like a voltage regulator going bad
>>that's built into a $1,000 computer board. (What ever happened to $15
>>regulators bolted to the firewall, anyhow?)[/color]
> No, but it might be the voltage regulator built into the $100 (for a
> full rebuild at a good local shop) alternator. Or the carbon brushes
> on the alternator rotor field slip rings could be worn and on the way
> out, but a rhythmic blink like that would be odd for brushes.
> Or there's a 'blinking' load on the system like the gauge voltage
> regulator in the instrument cluster, and there's a loose connection
> from the battery somewhere causing a voltage drop, making the pulsing
> load much more apparent. My first impulse would be to check all the
> battery cable connections (both positive and negative) and the chassis
> ground straps really carefully.
> --<< Bruce >>--
>[/color]
Thanks Bruce... After your answer, I doubt if it's the brushes, because
the rhythm doesn't change with engine rpm. I've admittedly not messed
with the negative connection, so I'll try that before taking it to a shop.
I'm having problems with the positive post connection because there's a
plastic "shield" thing that sits below the clamp (and next to the
battery) and that also has a little plastic spacer attached to it that
goes up vertically between the two halves of the post clamp. Because of
that spacer, I can tighten all I want on the post bolt, and it won't
clamp the battery post tight enough to prevent my moving the connection
on the (cleaned) post with just my hand and a big grunt. (Does that make
sense?) I wouldn't think I should be able to move it at all if it's
tight enough. BUT, the blinking does go away when the engine is stopped.
-- Steve
