Re: Manual transmission stuck in reverse on 1985 Toyota Camry
"aroberto" <robertdoerksen@netscape.net> wrote in message
news:1135633623.209574.35500@g14g2000cwa.googlegroups.com...[color=blue]
>I have a 1985 Toyota Camry that is stuck in reverse for no apparent
> reason. There were no wierd grinding or other noises. The clutch
> still works, but I cannot shift out of reverse.[/color]
I'd guess that the shift cable(s) are damaged / rusted solid. In any case,
you should be able to see the shift levers on the transmisison case, and
move them by hand (or with a hammer). Another possibility is something has
come adrift in the gear stick console area which is jamming the stick
assembly.
Stewart DIBBS
