Re: How to change the dashboard(Speedometer) light in Toyota Corolla 97
"njmodi" <njmodi2@yahoo.com> wrote:
[color=blue]
>reachsinha@gmail.com wrote:[color=green]
>> Hi,
>> I have been trying to find of how I can change the
>> dashboard(Speedometer) light, in Toyota Corolla 97. I think one of the
>> 3 bulbs in it is bad. Any help or guidance will be highly appreciated.
>> Thanks
>> AS[/color]
>While you are in there, replace all the bulbs - they are cheap. I had
>the same problem and replaced the one faulty bulb... I ended up with
>slightly different brightness on the gauge where I replaced the bulb...
>(I'm picky)... to top it off, another bulb blew two weeks later, so I
>had to pop out the cluster again ... 2nd time around, I replaced ALL
>the bulbs... so far so good.
>Cheers,
>Nirav[/color]
This might interest you...I flew for many years as a Flight
Engineer...on the F/E panel of the last a/c I flew there were
somewhere around sixty warning lights and power indicator lights.
Each one is in it's own holder which has a 'press to test'
feature built into it. It used to be our procedure when doing a
'pre-flight inspection' to 'press-to-test' every one of them to
ensure that the bulb was ok. Now, seeing as how a bulb's most
stressful event it just at the 'start of operation', I used to
argue against this process...I wrote suggestion after suggestion
that we abandon this wasteful and counterproductive action.
Guess what?...my suggestion was finally adopted and they started
doing that test on 100 hour inspections only by ground techs...I
didn't earn a hockeysock full of money but it sped our
'preflights' up a bit!...
-Gord.
(use gordon in email)
