highlander transmission poll ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2006, 03:36 PM   #1 (permalink)
Rob B
Guest
Posts: n/a
View Rob B's Photo Gallery
i am having troubles with '06 highlander tranny, dealer says operating
within specs.
I am curious if anyone else experience any of following problems or others
and if there are any solutions or reasons.
1. Shift Clunking
Noticeable unexpected clunking when shift from Park to Reverse
and Rev to Drive. Seem to be slight at first and then after about 700 miles
seems to be worse or more noticeable but not on all shifts just 70% time.
Plus New behavior at 1200 miles there is other new clunking. Sometimes
shifting out of park is very difficult as if the shifter is stuck ? and then
a large clunk when you do get it out of park. Sometimes it clunks while
putting it into Park. This occurs on flat surface or hill.
2. Surge / Lunge
After about 300 miles or so noticed When Stopping the car
(sometimes) surges/lunges a bit just before car comes to a stop. The lunge
mostly occurs under condition of accelerrate from stop to about 30-40 mph
then let off gas for a coast then apply brakes (i.e. stop/decelerate ) at
moderatly slow rate and then at about 5 mph if you slightly let off brake
just a tad then a surge/lunge like someone shoving you. So you need to get
on brake quickly so as not to hit car in front.
Essentially Stop and go traffic conditions.
3. LAG
When accelerating/Starting there seems to be a bit of LAG before
pick up.
4. TRAC
Some of these problems seem to disappear when you disable the TRAC or at
least lessen somewhat. that is surging and the LAG but the clunking stays.
One option i was curious about was people with "Tow Prep" (TOAT) option
installed . Supposedly from what i have read the Tow prep includes ,
Transmission fluid cooler, a higher amperage alternator, and a stronger
(3500lb ?) torque convertor. So i would like to determine if there is any
statistical evidence for Tow Prep problem ?
TIA
Robb
Old 01-04-2006, 04:44 PM   #2 (permalink)
Philip
Guest
Posts: n/a
View Philip's Photo Gallery
Re: highlander transmission poll ?
"Rob B" <RobB@where.on.net> wrote in message
news:ldXuf.2691$%W1.1266@newsread2.news.atl.earthlink.net...[color=blue]
> within specs.
> 1. Shift Clunking
> miles
> then
> 2. Surge / Lunge
> 3. LAG
> before
> pick up.
> 4. TRAC
> stays.
> TIA
> Robb[/color]
Welcome to the world of TOO MUCH crap technology.
Sounds like you have the V6 and 5 speed automatic. Both your throttle and
transmission are governed by the ECM. You have no direct cable linkage to
the throttle. You only tell the computer what you would like to happen.
Lexus has had the same gripes for a number of years on their fly-by-wire
throttle and 5 speed automatic ... and they STILL haven't got 'it' worked
out right.
Old 01-04-2006, 05:42 PM   #3 (permalink)
Louis M. Brown
Guest
Posts: n/a
View Louis M. Brown's Photo Gallery
On Wed, 04 Jan 2006 22:44:00 GMT, "Philip"
<1chip-state1@earthlink.net> wrote:
[color=blue]
>news:ldXuf.2691$%W1.1266@newsread2.news.atl.earthlink.net...[color=green]
>> within specs.
>> 1. Shift Clunking
>> miles
>> then
>> 2. Surge / Lunge
>> 3. LAG
>> before
>> pick up.
>> 4. TRAC
>> stays.
>> TIA
>> Robb[/color]
>out right.
>[/color]
I always have wondered just what the *hell* those engineers were
thinking when they started making every fucking thing computer
controlled. Ok, I can see *some* of the engine operations controlled
by computer, even the trans, but your throttle? What happens if your
comp. does the automobile version of the blue screen of death?
-LMB
Old 01-04-2006, 06:52 PM   #4 (permalink)
Philip
Guest
Posts: n/a
"Louis M. Brown" <phyphor@rocketmail.com> wrote in message
news:cinor1puqgqu1tqg91te7erpt0sd5gmd1m@4ax.com...[color=blue]
>[color=green]
>>news:ldXuf.2691$%W1.1266@newsread2.news.atl.earthlink.net...[color=darkred]
>>> within specs.
>>> others
>>> 1. Shift Clunking
>>> Reverse
>>> miles
>>> time.
>>> then
>>> 2. Surge / Lunge
>>> lunge
>>> mph
>>> at
>>> brake
>>> get
>>> 3. LAG
>>> before
>>> pick up.
>>> 4. TRAC
>>> stays.
>>> any
>>> TIA
>>> Robb[/color]
>>out right.
>>[/color]
> -LMB[/color]
Oh ... they'll tell you there is a "safety limp home mode" that would take
over. But obviously, ANYBODY who has a PC with Windows knows about
disagreements between hardware and software.
I bought a 2003 Corolla. They still had a mechanical throttle that year and
a four speed transmission that is capable of getting you home if the
transmission ECM loses its mind. Now the engine fuel management is another
matter.
If you want to see where all this unnecessary electronic control bull crap
is headed, take a look at a BMW 750 (E65 series). It's a robot car. You
only tell a computer what you'd like to have happen. This even includes the
parking brake application. Now far off is computer controlled steering.
Does the word "jackscrew" remind you of anything?
- Philip
Old 01-04-2006, 06:56 PM   #5 (permalink)
Dave Dave
Guest
Posts: n/a
View Dave Dave's Photo Gallery
sounds like the fly by wire throttle. have an 06 camry 4 and no
problems. work for hertz and have noticed with the highlander 6 and
camry 6 most of these problems you are having when driving. some are
worse than others. lots of them have a delay from when you press on the
excellator and when the engine speeds up.
Old 01-04-2006, 07:26 PM   #6 (permalink)
Dan J.S.
Guest
Posts: n/a
View Dan J.S.'s Photo Gallery
>[color=green]
>>> within specs.
>>> others
>>> 1. Shift Clunking
>>> Reverse
>>> miles
>>> time.
>>> then
>>> 2. Surge / Lunge
>>> lunge
>>> mph
>>> at
>>> brake
>>> get
>>> 3. LAG
>>> before
>>> pick up.
>>> 4. TRAC
>>> stays.
>>> any
>>> TIA
>>> Robb[/color]
>>out right.
>>[/color]
> -LMB[/color]
blue screen of death is microsoft... unix will not bsod... computers are far
more reliable than many people think... just their experience with windows
clouds judgment...
Old 01-04-2006, 08:32 PM   #7 (permalink)
Philip
Guest
Posts: n/a
"Dan J.S." <me@hyperx.com> wrote in message
news:11rote6mnir0uf0@news.supernews.com...[color=blue]
> news:cinor1puqgqu1tqg91te7erpt0sd5gmd1m@4ax.com...[color=green]
>>[color=darkred]
>>>> within specs.
>>>> others
>>>> 1. Shift Clunking
>>>> Reverse
>>>> miles
>>>> time.
>>>> then
>>>> 2. Surge / Lunge
>>>> lunge
>>>> mph
>>>> at
>>>> brake
>>>> get
>>>> 3. LAG
>>>> before
>>>> pick up.
>>>> 4. TRAC
>>>> at
>>>> stays.
>>>> any
>>>> TIA
>>>> Robb
>>>and
>>>to
>>>out right.
>>>[/color]
>> -LMB[/color]
> far more reliable than many people think... just their experience with
> windows clouds judgment...[/color]
Rubbish. I'm guessing Lexus has had this V6/5spd combo with fly-by-wire for
5 yrs now. Still have these chunky, clunky transmission behaviors and
lagging throttle response complaints. It was crap from the beginning and it
is still crap. This junk is all for ever tightening EPA regulations. It
certainly is not an answer for ANY question posed by customers.
There are things in a car that are truly an improvement when computerized
..... just like plastic pipes are to iron pipes in areas of hard water. But
they've gone too far and can't make it work smoothly. Time to admit the
whole idea has been an R&D experiment on the public and step back.
- Philip
Old 01-04-2006, 09:00 PM   #8 (permalink)
Rob B
Guest
Posts: n/a
"Dave Dave" <daveooo58@webtv.net> wrote in message
news:26946-43BC6ECC-1562@storefull-3355.bay.webtv.net...[color=blue]
>[/color]
it is highlander v6/5spd
part of the reason i purchased highlander was 2 week rental (test drive) in
early 2005, it was not *great* but good and it traveled well for my needs,
but now that i look back it may have been the 4cyl/4spd ?
but i have no idea whether rental had Tow-Prep installed , i am guessing not
on fleet cars
thanks for feedback
robb
Old 01-05-2006, 09:50 AM   #9 (permalink)
Dan J.S.
Guest
Posts: n/a
"Philip" <1chip-state1@earthlink.net> wrote in message
news:Ay%uf.2820$%W1.1557@newsread2.news.atl.earthlink.net...[color=blue]
> news:11rote6mnir0uf0@news.supernews.com...[color=green]
>> news:cinor1puqgqu1tqg91te7erpt0sd5gmd1m@4ax.com...[color=darkred]
>>>>> within specs.
>>>>> others
>>>>> 1. Shift Clunking
>>>>> Reverse
>>>>> miles
>>>>> time.
>>>>> and
>>>>> then
>>>>> while
>>>>> 2. Surge / Lunge
>>>>> lunge
>>>>> mph
>>>>> at
>>>>> brake
>>>>> get
>>>>> 3. LAG
>>>>> before
>>>>> pick up.
>>>>> 4. TRAC
>>>>> at
>>>>> stays.
>>>>> option
>>>>> stronger
>>>>> any
>>>>> TIA
>>>>> Robb
>>>>and
>>>>to
>>>>worked
>>>>out right.
>>> -LMB[/color]
> for 5 yrs now. Still have these chunky, clunky transmission behaviors and
> it is still crap. This junk is all for ever tightening EPA regulations.
> It certainly is not an answer for ANY question posed by customers.
> But they've gone too far and can't make it work smoothly. Time to admit
> the whole idea has been an R&D experiment on the public and step back.
> - Philip
>[/color]
You have to re-read my argument. I didn't say toyota should not re-program
their stuff. I am saying computers are extremely reliable, just that because
of our experience with crappy computers and idiot customers service people
blaming everything on computers, people think computers are unreliable.
Old 01-05-2006, 10:58 AM   #10 (permalink)
Philip
Guest
Posts: n/a
news:11rqg2a35ra6q4b@news.supernews.com...[color=blue]
> news:Ay%uf.2820$%W1.1557@newsread2.news.atl.earthlink.net...[color=green]
>> news:11rote6mnir0uf0@news.supernews.com...[color=darkred]
>>> news:cinor1puqgqu1tqg91te7erpt0sd5gmd1m@4ax.com...[/color][/color][/color]
snip[color=blue][color=green][color=darkred]
>>>> -LMB
>>> Blue screen of death is microsoft... unix will not bsod... computers are
>> and lagging throttle response complaints. It was crap from the beginning
>> and it is still crap. This junk is all for ever tightening EPA
>> regulations. It certainly is not an answer for ANY question posed by
>> customers.
>> - Philip
>>[/color]
> because of our experience with crappy computers and idiot customers
> service people blaming everything on computers, people think computers are
> unreliable.[/color]
Re-reading your post changed nothing. Toyota HAS attempted reprograming and
hardware modifications NUMEROUS TIMES over the run of this fly-by-wire/5spd
auto combination and has yet to get the package performing smoothly. Yet
they see fit to trickle down this crap to another model.
You put too much faith in automation. Admit it. You embrace being a beta
tester for this crap. I sure as hell do not. There are many situations
where computer automation as been done for its own sake ... not because it
was best. As a customer, I would NOT put up with such chunky, clunky,
lagging behavior when I've just spent so much money ... especially in the
Lexus line where this crap started and continues.
- Philip
Old 01-05-2006, 05:47 PM   #11 (permalink)
Philip
Guest
Posts: n/a
>>>>>> within specs.
>>>>>> others
>>>>>> 1. Shift Clunking
>>>>>> Reverse
>>>>>> miles
>>>>>> time.
>>>>>> Sometimes
>>>>>> and
>>>>>> then
>>>>>> while
>>>>>> 2. Surge / Lunge
>>>>>> lunge
>>>>>> mph
>>>>>> brake
>>>>>> to get
>>>>>> 3. LAG
>>>>>> before
>>>>>> pick up.
>>>>>> 4. TRAC
>>>>>> at
>>>>>> stays.
>>>>>> option
>>>>>> stronger
>>>>>> any
>>>>>> TIA
>>>>>> Robb
>>>>>and
>>>>>to
>>>>>happen.
>>>>>fly-by-wire
>>>>>worked
>>>>>out right.
>>>> -LMB
>> customers.
>> - Philip
>>[/color]
> unreliable.[/color]
This article is from 13 months ago ...
[url]http://www.post-gazette.com/pg/04345/424551.stm[/url]
Hesitation issue goes beyond Toyota's luxury line
Friday, December 10, 2004
By Don Hammonds, Pittsburgh Post-Gazette
Toyota engineers are working to find an acceptable fix for a
hesitation problem in five-speed automatic transmissions in
certain of its luxury Lexus and Toyota models, the Japanese
automaker said yesterday.
The problem was brought to light this week when the
Post-Gazette reported on troubles McMurray resident
Timothy W. Farabaugh was having with his 2004 Lexus
ES330 ("Hesitating Lexus unsettling for owners,"
Dec. 8, 2004). The vehicle didn't respond immediately
when his wife pressed the accelerator while trying to
merge into traffic, causing her to narrowly avoid an
accident.
It became clear the problem was more widespread when
other readers who saw Wednesday's PG story reported
the same hesitation with their Toyotas and other Lexus
models.
It turns out that the five-speed automatic in the 2002 to
2004 Lexus ES300 and ES330 models also is used in
the Toyota Highlander and Lexus RX330 sport utility
models, two of the company's biggest sellers.
"The engineers in Japan are trying to come up with a
fix on this problem ... The first attempt to solve this
has not been completely successful," said Toyota
spokesman Wade Hoyt. That first attempt "involved
reprogramming the computer that controls the
transmission," he added.
The reprogramming "relieved part of the problem,
but did not completely cure it,'' he said -- a statement
with which Alvise Anti of Pittsburgh can concur.
She said her RX330 had the "update -- Lexus calls it
the fix -- but obviously it's not working. The car is
drivable, but if you are not aware of the problem, it
can be dangerous."
Another owner, Beth Caldwell, said her 2004 Toyota
Highlander V-6 with the five-speed automatic transmission
had the same hesitation problem and that when she took
it to the dealer's service department, she was told "that's
how the new transmissions are."
Scott McAliley said he got a similar response when he
approached his dealer about his 2004 Lexus ES330. He
said the dealer told him that, "a.), They couldn't find
anything out of the ordinary and b.), The problem
would diminish over time as the computer learned
our habits."
One 2002 ES330 owner, Michael Moran, said he "made
contact with the customer service department at Lexus
headquarters in California, which led to a test drive of
my car and a resultant confirmation of the malfunctioning
transmission.
"I was offered a new 2004 ES330 for $4,000, an offer I
unfortunately accepted. ... The 2004 ES330 model I am
now driving has an even more pronounced malfunctioning
transmission."
There have been no reports of serious or fatal accidents
because of the problem.
Spokesman Brad Nelson said that once Toyota comes up
with a successful fix, it may issue a technical service bulletin
to dealers so they could make repairs on cars when they are
brought in or launch a service campaign that would notify
owners that there is an issue and that the problem can be
corrected.
Hoyt said he believed that only drivers who were unusually
sensitive to their cars' shifts and performance would notice
the hesitation.
Old 01-05-2006, 07:21 PM   #12 (permalink)
ma_twain
Guest
Posts: n/a
View ma_twain's Photo Gallery
Philip wrote:
[color=blue]
>[color=green]
>>[color=darkred]
>>>>[/color][/color]
> snip
>>>>>-LMB
>>>customers.
>>> - Philip
>>>[/color]
>>unreliable.
>>[/color]
>[/color]
I noticed this hesitation in other cars with computer controller
automatic transmissions. That is why our new Toyota has a manual
transmission - no hesitation! Unfortunately, Toyota is not selling as
many models with manual transmission. I also hate to say it, but I like
the handling of rear wheel drive, so bring back the Supra - with a
manual transmission!
BB code is Off
Smilies are Off
[IMG] code is Off
HELP: Serious Transmission Problems arcasmachineracing Camry & Solara Lounge 23 06-22-2008 11:53 PM
Toyota Announces Prices For All-New Hybrid Synergy Drive-Powered Highlander Hybrid SU Ratko Toyota News 6 05-13-2005 11:03 PM
2006 Toyota Highlander Hybrid Price Announcement isaiah58 Toyota News 0 03-29-2005 01:18 PM
Highlander Hybrid Suv Will Make Canadian Debut In Montreal rolla-XRS Toyota News 4 01-14-2005 12:29 AM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 10:06 AM
