Re: 94 tercel check engine light code retrieval
On Sun, 08 Jan 2006 03:19:38 +0000, Matt wrote:
[color=blue]
> qslim wrote:[color=green]
>> Yeah, find the diagnostic connector under the hood and open it. Should be
>> TE1 and E2. Jump the terms with a paper clip or bit of wire, turn the
>> ignition on, and the light should try to tell you something. Let us know
>> what you get.
>>[/color]
> Can you be any more specific as to where that might be? Is it near the
> fuse box?
> Thanks
> Matt[/color]
It may be near the battery. It has a curved cover over it that says
DIAGNOSTIC. There will be a diagram inside showing where the connections
are. On a '95, it was between the fuse block under the hood and the
firewall.
Have your Virtual Pet spayed/neutered!!
