87 Toyota won't start without starting fluid. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2006, 04:21 PM   #1 (permalink)
Chris3539
Guest
Posts: n/a
View Chris3539's Photo Gallery
The alternator is new. The cold start valve is working. Battery is
charged. Plugs are new. Any advice?
Old 01-07-2006, 04:25 PM   #2 (permalink)
Chris3539
Guest
Posts: n/a
Re: 87 Toyota won't start without starting fluid.
This is still Chris posting: The timeing is set right!
Old 01-07-2006, 05:01 PM   #3 (permalink)
Chris3539
Guest
Posts: n/a
It is started but won't go in gear now.
Old 01-07-2006, 05:20 PM   #4 (permalink)
Chris3539
Guest
Posts: n/a
Could it be the catalitic converter???
Old 01-07-2006, 05:22 PM   #5 (permalink)
Chris3539
Guest
Posts: n/a
Old 01-07-2006, 08:28 PM   #6 (permalink)
Joey
Guest
Posts: n/a
View Joey's Photo Gallery
Chris3539 wrote:
[color=blue]
>[/color]
Chris,
Tell us a little more about the cars history and what you've done so
far. Starting problem could be the fuel pump. The other might be a
different story. Please tell us more info.
J
Old 01-07-2006, 09:47 PM   #7 (permalink)
mickeyd's Avatar
View mickeyd's Photo Gallery
there is a cold start injector time swich that tells your cold start injector to open and add additional fuel when its cold, then as the engine warms, tells the injector to shut off. it is located on the water neck on the drivers side the head.
mickeyd is offline
Old 01-08-2006, 03:28 PM   #8 (permalink)
Chris3539
Guest
Posts: n/a
New motor, cranks and idles, when you put it in gear it dies, unpluged
throdle censor and put it in gear will still idle but will not go but as
soon as you touch the gas it dies, new distributor, new cap, new rottery
button, new plugs and wires, cold start valve is good, cold start sensor
is broke, acts like it's not getting enough gas when engaged.
Old 01-08-2006, 03:31 PM   #9 (permalink)
Chris3539
Guest
Posts: n/a
BB code is Off
Smilies are Off
[IMG] code is Off
Toyota to Offer XM Radio as a Factory-Installed Option EKam Toyota News 1 08-17-2011 06:53 PM
surpercharge 3VZ-FE possible? gmfb3VZ-FE Hardcore Tech and Competition 24 04-26-2010 09:24 PM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
Do I had to stick toyota transmisson fluid? SKJ69NYC General Discussion 6 12-18-2005 08:32 AM
