Re: Shifter stuck in park No brake lights 99 Corolla
On Sun, 08 Jan 2006 04:17:01 -0000, rogplayer <rg@xcite.com> wrote:
[color=blue]
>The shifter in my daughters 99 corolla is stuck in park. Also no brake
>lights. Replaced all bulbs. I replaced the stop light switch on the brake
>pedal thinking that was the problem but still no brake lights. Has power to
>the switch. Fuse behind the dash kick panel is ok. Don't see any
>breaks/worn wires in trunk area. All bulb sockets seem to be fine. Pulled
>out the shift lock solenoid (yea what a fun job that is) in the center
>console. Don't know if it is good or bad. Local dealer wants 220 dollars
>for a new one. Anyone have any ideas? Is a real stumper for me.
>A while back car was having a weird electrical problem that seemed to
>correct itself. The high beam indicator on the dash would flash on and off
>when driving. Could hear the headlight relay under the hood clicking when
>it would occur. And occationally the headlights/running lights would stay
>on after the car was turned off. These problems haven't happened for a
>while now but with my luck lately it's probably all related. Thanks for any
>sugestions.[/color]
Like QSlim said, it's the stoplight circuit - there's a lock
solenoid actuated by the brakelight power so you have to have your
foot on the brake to shift out of Park, and with the brakelight
circuit out the solenoid is not actuating.
Read the Owner's Manual. There is a place to pop a trim cover on
the center console and push in a pin to push the latch solenoid open
and manually unlock the shifter. So you can CAREFULLY drive the car
to the mechanic and avoid a tow bill.
Remember to open the window and hand-signal you are stopping - arm
down. (That's why they still cover hand signals in Drivers' Ed. Some
people actually manage to stay awake during that part...)
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
