Re, Brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2006, 06:18 PM   #1 (permalink)
Digit
Guest
Posts: n/a
View Digit's Photo Gallery
Re, Brakes
Need to know what tools, other then basic hand tools ,that are needed to
replace pads and rotors on a 2003 corolla.
Old 01-12-2006, 06:32 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Re, Brakes
"Digit" <ddpowell@paulbunyan.net> wrote in message
news:e358b2af60e17fa2a653201e13f9a871@localhost.talkaboutautos.com...[color=blue]
>[/color]
Yes, you would need to know what tools, other than basic hand tools, are
needed to replace pads and rotors on a 2003 Corolla so you can assemble the
tools prior to attempting the work.
You will need:
A jack
Jack stands
A wheel chock
A can of brake cleaner
Set of metric wrenches inclcuding 12 through 16 mm and whatever size is
needed to remove the wheel lug nuts
Wire brush (toothbrush size is good) to clean up the clips and springs
Flat bladed pry bar or screwdriver to get the caliper off
Safety glasses
High temperature wheel bearing grease or anti-seize to use on the slides and
hub-rotor-wheel interface
Rags or paper towels
A couple of quarts of brake fluid if you want to flush it while you're at it
(add a 10 mm box wrench and container to catch the flushed brake fluid to
the list of tools)
The list of "nice to have" tools would include an air compressor, impact
wrench and impaqct sockets,. air ratchet, vehicle lift, and parts washer.
Ray O
Old 01-12-2006, 07:50 PM   #3 (permalink)
Dave
Guest
Posts: n/a
View Dave's Photo Gallery
Re: Re, Brakes
In my opinion any person that needs to ask what tools he needs to replace
brakes should also have an experienced helper to insure that all is done
correctly. Brakes are simple to replace if done properly. Regards Dave
>[/color]
Old 01-12-2006, 07:58 PM   #4 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
Re: Re, Brakes
On Thu, 12 Jan 2006 17:32:25 -0600, "Ray O"
<rokigawa@tristarassociatesDOTcomn> wrote:
[color=blue]
>news:e358b2af60e17fa2a653201e13f9a871@localhost.talkaboutautos.com...[color=green]
>>[/color]
>You will need:
>A jack
>Jack stands
>A wheel chock
>Safety glasses
>the list of tools)
>wrench and impaqct sockets,. air ratchet, vehicle lift, and parts washer.[/color]
.......and a buddy that is a Toyota MDT
.......and a case of beer for your buddy
Would be my advice....
Scott in Florida
Old 01-12-2006, 09:24 PM   #5 (permalink)
Gord Beaman
Guest
Posts: n/a
View Gord Beaman's Photo Gallery
Re: Re, Brakes
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote:
[color=blue]
>>[/color]
>You will need:
>A jack
>Jack stands
>A wheel chock
>Safety glasses
>the list of tools)
If it were me I'd add a knowledgeable blonde tech with long legs
so I could watch her work as I quaffed a cool one and gave
advice...(but then, that's just me)...YMMV... :)
-Gord.
(use gordon in email)
Old 01-12-2006, 09:44 PM   #6 (permalink)
ron
Guest
Posts: n/a
View ron's Photo Gallery
Re: Re, Brakes
I agree! Remember the old adage, "you got a lot riding on your
brakes"? Simple to do, but also easy to foul up.
But I might also add its useful to have a c clamp to compress the
wheell cylinders also (what I used anyhow).
"Dave" <12345@canada.ca> wrote in message
news:JPCxf.204852$2k.204008@pd7tw1no...[color=blue]
> replace
> done
> Dave
>> needed to
>>[/color]
>[/color]
Old 01-12-2006, 11:04 PM   #7 (permalink)
Digit
Guest
Posts: n/a
Re: Re, Brakes
Thanks for the Info. 25 year GM Tech so tools are not a concurn. First
Inport I have worked on. Thanks to all.
Old 01-13-2006, 12:06 AM   #8 (permalink)
Ray O
Guest
Posts: n/a
Re: Re, Brakes
"Scott in Florida" <JustAsk@Florida.com> wrote in message
news:houds1pph414d3nrove8rnq9ehk3054c67@4ax.com...[color=blue]
>[color=green]
>>news:e358b2af60e17fa2a653201e13f9a871@localhost.talkaboutautos.com...[color=darkred]
>>>[/color]
>>the
>>You will need:
>>A jack
>>Jack stands
>>A wheel chock
>>Safety glasses
>>and
>>it
>>the list of tools)
> Scott in Florida[/color]
Fortunately, a brake job is not rocket science so almost any experience with
disc brakes is enough.
Ray O
Old 01-13-2006, 12:08 AM   #9 (permalink)
Ray O
Guest
Posts: n/a
Re: Re, Brakes
"Gord Beaman" <gord@islandtelecom.com> wrote in message
news:jh3es1psht9d0qr2c7up05dsju7qs72gsm@4ax.com...[color=blue]
>[color=green]
>>>[/color]
>>the
>>You will need:
>>A jack
>>Jack stands
>>A wheel chock
>>Safety glasses
>>and
>>it
>>the list of tools)
> -Gord.
> (use gordon in email)[/color]
I'd heard of a female brunette Hyundai tech who supposedly worked as an
"exotic dancer" and could probably handle the brake job without any
problems...
Ray O
Old 01-13-2006, 12:10 AM   #10 (permalink)
Ray O
Guest
Posts: n/a
Re: Re, Brakes
"ron" <really [email]good@serviceu.com[/email]> wrote in message
news:auExf.2177$_S7.1865@newssvr14.news.prodigy.com...[color=blue]
>I agree! Remember the old adage, "you got a lot riding on your brakes"?
> But I might also add its useful to have a c clamp to compress the wheell
>[/color]
Good point about the C clamp. I always forget to get it out when I'm
gathering tools for a brake job. Some people use water pump pliers instead
of a clamp but I find the clamp a lot easier to use.
Ray O
Old 01-13-2006, 12:12 AM   #11 (permalink)
Ray O
Guest
Posts: n/a
Re: Re, Brakes
news:0b08909c2f16074733d2517d9f516641@localhost.talkaboutautos.com...[color=blue]
>[/color]
No special tools are necessary. The bolts holding the caliper on are
regular bolts and a lot easier to get to than the hex setup on GM's.
Ray O
Old 01-13-2006, 12:27 AM   #12 (permalink)
Scott in Florida
Guest
Posts: n/a
Re: Re, Brakes
On Thu, 12 Jan 2006 23:08:50 -0600, "Ray O"
[color=blue]
>news:jh3es1psht9d0qr2c7up05dsju7qs72gsm@4ax.com...[color=green]
>>[color=darkred]
>>>the
>>>You will need:
>>>A jack
>>>Jack stands
>>>A wheel chock
>>>Safety glasses
>>>and
>>>it
>>>the list of tools)
>> -Gord.
>problems...[/color]
She could handle my 'brake' job....
Scott in Florida
Old 01-13-2006, 03:03 AM   #13 (permalink)
Slim Pickings
Guest
Posts: n/a
View Slim Pickings's Photo Gallery
Re: Re, Brakes
Ignorant, lazy, bottom posters.
A perfect example.
Slim
On Fri, 13 Jan 2006 00:27:49 -0500, Scott in Florida
<JustAsk@Florida.com> wrote:
[color=blue]
>[color=green]
>>news:jh3es1psht9d0qr2c7up05dsju7qs72gsm@4ax.com...[color=darkred]
>>>>the
>>>>You will need:
>>>>A jack
>>>>Jack stands
>>>>A wheel chock
>>>>Safety glasses
>>>>and
>>>>it
>>>>the list of tools)
>>> -Gord.
>>problems...[/color]
>She could handle my 'brake' job....[/color]
Old 01-13-2006, 09:30 PM   #14 (permalink)
TeGGeR®
Guest
Posts: n/a
View TeGGeR®'s Photo Gallery
Re: Re, Brakes
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in
news:42d02$43c73918$180fead6$26656@msgid.meganewsservers.com:
[color=blue]
> experience with disc brakes is enough.[/color]
Ever worked on Lambert discs?
TeGGeR®
Old 01-13-2006, 10:12 PM   #15 (permalink)
Philip
Guest
Posts: n/a
View Philip's Photo Gallery
Re: Re, Brakes
"TeGGeR®" <tegger@tegger.c0m> wrote in message
news:Xns974ADB1B5635Etegger@207.14.113.17...[color=blue]
>[color=green]
> TeGGeR®
>[/color]
John! Drop me a line.
- Philip
BB code is Off
Smilies are Off
[IMG] code is Off
Got cams? Got brakes? JekylandHyde MR2 Forum 6 07-13-2005 06:26 AM
Brakes Challenge 1989 Celica HARVICKFAN Celica Forum 2 04-15-2005 11:16 AM
Changing Drum Brakes to Disk Brakes on 2003 LE DragonR6 5th & 6th Generation (2002-2006 & 2007-2011) 1 12-10-2004 05:07 PM
Conversion Kit - Rear Drum Brakes To Disc Brakes Nikolas Archived Corolla threads 5 08-20-2004 11:38 PM
New brakes? CrawlingEye Camry & Solara Lounge 20 03-22-2004 01:14 AM
