Re: 95 Corolla right CV axle reassembly problem
I tried that exact technique you described and still no go. I'm pretty
sure the part is correct, but I'm giving up and taking it (towing it)
to a mechanic.
I appreciate the suggestions even thought I couldn't get 'er in there.
qslim wrote:[color=blue]
> Well, assuming you know that the part is correct, the snap ring deal is the
> only real roadblock you should have. I usually set it up as I previously
> described and use the axle itself as a kind of slide hammer to knock it in
> to the diff, if that makes sense. Get it splined inside the diff, then give
> a little pull on the wheel end of the axle and knock it forward.
> If that doesn't work I pick up the ol' dead blow plastic-faced hammer,
> have someone hold the shaft up and solid to the diff, and give it a good
> whack. It takes two people sometimes.[/color]
