Follow Up - Too Lean - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2006, 07:48 PM   #1 (permalink)
jor
Guest
Posts: n/a
View jor's Photo Gallery
2000 Avalon
I posted a couple of weeks ago and got some good advice from qslm and Ray.
Anyhow, my Avalon's "check engine" light was on. The Autozone diagnostic
indicated a too lean condition (you were right, qslm; it was, indeed, code
PO171). Anyhow, as suggested, I took out the MAV sensor. It looked fine but
I hit it with a little air and gave the platinm wire a soft brushing. I put
it back together and the light is now off. Is it fixed? Who knows?
Now, I have a question re the MAV diagnostic suggested in the Haynes manual.
It says to read the voltage between connector #4 and ground. The manual
indicates that the voltage should be 9 to 14v. I am reading 4.25 volts. Is
this normal? Thanks.
jor
Old 01-29-2006, 09:40 PM   #2 (permalink)
qslim
Guest
Posts: n/a
View qslim's Photo Gallery
Re: Follow Up - Too Lean
<<<<<manual.
volts.>>>>>
I'm assuming you mean pin #4 of the connector at the MAF (mass air flow)
sensor. I can't think of the connector layout right now, but I want to say
that the sensor should not have battery voltage as your manual indicates,
but rather ECU voltage which is close to 5V. But like I said I can't
picture it in my head right now. (BTW the ECU itself and all its
peripherals run off of 5V)
In any case, I find that about 50% of Avalons that come in with that
code simply have some crap on the sensing wire up inside the body of the
sensor, and cleaning it with shop air or that computer-cleaning stuff in a
can usually works.
BB code is Off
Smilies are Off
[IMG] code is Off
Engine Code 25 --> Lean Exhaust. still Tercel, Paseo, Starlet, and Sera Forum 3 12-23-2005 12:21 PM
car running lean.... need help 05Cam-Weasel Camry & Solara Lounge 1 10-31-2005 08:51 AM
System too lean? RXTech Archived Corolla threads 5 05-12-2005 01:02 AM
5efhe running lean dexter_5000 Hardcore Tech and Competition 0 11-21-2004 09:42 AM
Possible Causes For System Too Lean BustaRice Camry & Solara Lounge 8 03-03-2004 01:03 AM
