Re: 1995 Camry advice needed
"Alex" <sandycruden@gmail.com> wrote in message
news:1138627953.647434.261650@g43g2000cwa.googlegroups.com...[color=blue]
> Hi Guys can you give me some advice please?
> I have a 1995 Camry with 178k on the clock. Every few days whilst
> driving, the red warning light shaped like a battery and the yellow
> light which appears to be the brake light warning come on
> simultaneously for around 5 seconds and then they go out again, no
> other symptoms are evident. Could this be the forerunner to a problem?[/color]
check the connections to your battery - make sure the battery clamps are
tight and free of corrosion. If the battery is more than 5 years old, it is
time to think about a replacement.
[color=blue]
> Also I find the remote key door lock/unlock is getting very sluggish,
> sometimes I have to push the activator button on the key 5 or 6 times
> before getting a result I have changed the battery in the key but that
> has not helped. Any advice would be really appreciated.
> Alex[/color]
Take the remove apart and clean the contacts on the rubber switch and
circuit board with rubbing alcohol. it may improve a little but the
contacts on the rubber are probably getting worn.
Ray O
