Removing door panel to replace outside handle - 1995 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2006, 09:12 PM   #1 (permalink)
pete0123
Guest
Posts: n/a
View pete0123's Photo Gallery
Can anyone tell me how to remove my inside door panel so I replace a
broken drivers side door handle? I have removed all the screws holding
the panel in place, but the window winder is giving me some troubles.
How do you remove the winder??
Old 02-06-2006, 10:37 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Removing door panel to replace outside handle - 1995 Camry
"pete0123" <pete_limon@hotmail.com> wrote in message
news:1139281938.335052.171060@g43g2000cwa.googlegroups.com...[color=blue]
>[/color]
The window crank (what you call the "winder") is held in place with a
C-shaped wire clip. If you push in on the door panel around the base of the
crank, you may be able to see a piece of wire that is a little thicker in
diameter than a large paper clip in a slot on the inside of the base of the
crank. You may have to rotate the crank to see the end of the clip - I'd
position the clip so that the openings are facing upwards. You can use a
small screwdriver to pop one end of the C off of the crank - it moves
parallel to on the face of the inner door panel, or you can use a rag like
dental floss to snag one end of the clip. I recommend doing this with the
door closed so that when the clip goes flying, it won't go as far and if you
position the crank so that the openings are facing upwards, it will fly down
towards the floor. To re-install the crank, first place the crank on the
spline without the clip to roll the window up and position the crank as you
would like it, then remove the crank, re-install the C clip in the slot on
the crank, then pop the crank back on the spline.
Ray O
Old 02-28-2006, 12:59 PM   #3 (permalink)
cjboerger@gmail.com
Guest
Posts: n/a
View cjboerger@gmail.com's Photo Gallery
Check this out.
[url]http://autorepair.about.com/od/otherodddiyjobs/l/aa092504a.htm[/url]
Ray O wrote:[color=blue]
> news:1139281938.335052.171060@g43g2000cwa.googlegroups.com...[color=green]
> >[/color]
> Ray O
> (correct punctuation to reply)[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
1997 toyota camry door handle steelframe 3rd & 4th Generation (1992–1996 & 1997–2001) 0 06-02-2005 09:40 AM
2005 Camry Door handle Question xpeed 5th & 6th Generation (2002-2006 & 2007-2011) 4 01-04-2005 08:38 PM
Battery ?'s 1995 camry V6 LE kenny1773 3rd & 4th Generation (1992–1996 & 1997–2001) 14 11-29-2004 03:29 PM
