91 camry won't start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2006, 11:30 PM   #1 (permalink)
bxgirl2003@hotmail.com
Guest
Posts: n/a
View bxgirl2003@hotmail.com's Photo Gallery
I have a 91 Camry that will not start!! There is no electrical problem,
ppl say it sounds like i have no gas in my tank when i actually have a
full tank.. what can it be???
Old 02-06-2006, 11:42 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 91 camry won't start
<bxgirl2003@hotmail.com> wrote in message
news:1139290239.696515.301390@z14g2000cwz.googlegroups.com...[color=blue]
>[/color]
How do you know there is no electrical problem? Does the starter engage and
is there spark at each cylinder?
Is fuel being delivered to the injectors?
Start with the basics - air, fuel, and spark at the appropriate times.
Ray O
Old 02-06-2006, 11:46 PM   #3 (permalink)
Steve.R.Gilbert@gmail.com
Guest
Posts: n/a
View Steve.R.Gilbert@gmail.com's Photo Gallery
timing belt probably. did it just stop? if it did that is probably the
reason
Old 02-08-2006, 10:52 AM   #4 (permalink)
Guest
Posts: n/a
its not the and there are sparks on each cylinder, at first they
thought it was the gas filter but its not, not they are thinking it is
the fuel pump...
Old 02-08-2006, 11:09 AM   #5 (permalink)
Ray O
Guest
Posts: n/a
news:1139417550.606989.65380@g44g2000cwa.googlegroups.com...[color=blue]
> the fuel pump...
>[/color]
It would be helpful if you did not delete prior posts so that people
responding to your request know or remember what was suggested.
If you are getting spark at each cylinder, then the remaining possibilities
are air, fuel, and timing.
Make sure thee air filter is not clogged.
The proper way to check for fuel delivery is to install a fuel pressure
gauge. If there is no fuel pressure, then the fuel pump is a possible
culprit. Check for power at the fuel pump.
Assuming that the engine cranks, does it crank more quickly than normal? If
so, then the timing belt may be broken.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
91 Camry V6 won't start - help! monkeytoes 1st & 2nd Generation (1983–1986 & 1987-1991) 17 01-20-2006 01:38 PM
Recaros Start seats are now just $195.95! Buy last years close out fabrics and save! Safe Drives Supporting Vendor Sales 0 11-09-2005 07:17 PM
91 Camry - Wheel Offset and Handling Question tvictor 1st & 2nd Generation (1983–1986 & 1987-1991) 2 11-07-2004 12:55 PM
Anyone fixed a broken sunroof? (91 Camry Wgn) 1966CL77 General Discussion 0 10-28-2004 12:44 AM
96 Camry 4 cylinder won't start jjanari 3rd & 4th Generation (1992–1996 & 1997–2001) 1 06-02-2004 05:01 PM
