Checking Transmission Fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2006, 07:29 AM   #1 (permalink)
jor
Guest
Posts: n/a
View jor's Photo Gallery
2000 Avalon
I just had my transmission fluid changed. I noted when the engine was
running and warm that the fluid level registered at the "cold" mark on the
dipstick. I called the mechanic and he told me that, according to Toyota,
the fluid level on an Avalon should be checked when the engine is not
running. My owner's manual does not cover this but my Haynes manual
indicates it should be checked with the engine running (like every other
automatic I have ever owned). So which is it? Thanks.
jor
Old 02-07-2006, 10:19 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Checking Transmission Fluid
"jor" <jor@jor.com> wrote in message
news:LrudnRCoFbU7PXXeRVn-sw@comcast.com...[color=blue]
> 2000 Avalon
> jor[/color]
Generally, automatic transmission fluid level should be checked with the
engine running, transmission in park, and warmed up.
Ray O
Old 02-07-2006, 01:00 PM   #3 (permalink)
qslim
Guest
Posts: n/a
View qslim's Photo Gallery
That mechanic is dead wrong. Check it on a level surface while running.
Old 02-07-2006, 11:03 PM   #4 (permalink)
n877@msn.com
Guest
Posts: n/a
View n877@msn.com's Photo Gallery
When the engine is running the torque coverter is full. When not
running the fluid in it seeks its own level by draining back into the
sump. Checking with the engine not running will show an overfull
condition.
Ron
Old 02-08-2006, 07:41 AM   #5 (permalink)
jor
Guest
Posts: n/a
> 2000 Avalon
> running and warm that the fluid level registered at the "cold" mark on the[/color]
Thanks to all for the answer on this. I figured that was the case.
jor
BB code is Off
Smilies are Off
[IMG] code is Off
Transmission fluid level touringcamry Camry & Solara Lounge 9 06-26-2005 09:35 AM
Draining & flushing the Automatic Transmission fluid while the car is running cato47 Camry & Solara Lounge 0 06-24-2005 06:55 AM
Transmission fluid drain % total1 General Discussion 7 06-03-2005 07:28 PM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 10:06 AM
Checking transmission fluid on AE100 rankiad Archived Corolla threads 3 07-06-2002 01:55 PM
