Re: DTC code P0420 for 1996 CAMRY
<jaguar_babu@hotmail.com> wrote in message
news:1139550110.895717.183000@o13g2000cwo.googlegroups.com...[color=blue]
>I have a P0420 code for 1996 camry. The code reads 'Catalyst efficiency
> below threshold (bank 1)'. How many Three way catalytic converters are
> there for 1996 camry. Mine 4 cylinder 2.2l (5S-FE). I read in
> alldatadiy.com, that there will be two catalytic converters for this
> model. If yes, then which one do you think failed. Is it the front
> converter (at the start of exhaust) or the rear converter?
> JSB.
>[/color]
A more likely cause is that the O2 sensor after the second cat is marginal,
giving bad signals. Luckily, an O2 sensor is a lot less than a catalytic
converter.
Ray O
