Re: Help Starting dilemma
"Dan49" <danubo49@msn.com> wrote in message
news:750e9382422d98758de03bbf423b83f6@localhost.talkaboutautos.com...[color=blue]
>I have a toyota celica St 89 model, benn parked for over a year and decided
> to give life to it again, it used to run,but the engine won't sustain
> running for long after i did some tune up measure, so i decided to parked
> it and forget. Now i want to run it again but it won't even cranked.
> Changed the battery, checked starter/solenoid at autozone and it runs ok,
> put it back and the same proble, planning to check my fuses and relays
> next time because the starter will not budge at all. How would i proceed
> with the problem, any help will greatly be appreciated
>[/color]
If the car has an automatic transmission, try shifting into neutral and see
if the engine cranks. If it does, then the neutral safety switch is
probably the culprit.
If the car has a manual transmission, try push starting.
If those measures do not work, disconnect the battery cables and see if you
can turn the engine over by hand by putting a wrench on the lower pulley
bolt.
Ray O
