Re: corolla oil consumption, seems to be common
"Alex" <someone@microsoft.com> wrote in message
news:L%pIf.13096$2O6.10133@newssvr12.news.prodigy.com...[color=blue]
>I am continuing to search for oil consumption related posts. I burn about
>a quart every 500 miles; no visible smoke, no leaks and I foul plug 4 each
>5000 miles or so. My consumption rate points to the valve guide seals.
>The problem is not common, but not infrequent either. How could Toyota
>continue to use these same seals over so many years of production? The fix
>is moderately expensive, and most just live with the oil consumption. It
>leaves the tail pipe black, and leaves a black soot on the back bumper. In
>this age of clean exhaust, and 95 standards are pretty clean, why didn't
>Toyota change this with the 90 or 91 production? And it continues on the
>same motor thru 97.[/color]
Some Toyota engines have hardened valve guide seals that leak. I'm sure
there have been production changes in the seals over the years.
Ray O
