valve cover gasket oil leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2006, 03:08 PM   #1 (permalink)
badgolferman
Guest
Posts: n/a
View badgolferman's Photo Gallery
My 2000 Sienna with 92K miles has valve cover gasket oil leaks. Both
gaskets have a slight leak with the front one being worse. The dealer
wants $690 to fix it. I am not going to pay that price for it.
Are there different oils or additives I should use to minimize the
leak? It isn't bad enough to show on the ground yet.
Currently I use Valvoline 5W-30 oil every 3000 miles.
Old 02-18-2006, 03:57 PM   #2 (permalink)
Mike Hunter
Guest
Posts: n/a
View Mike Hunter's Photo Gallery
Re: valve cover gasket oil leak
Have you tried tightening the bolts? A bid of preventive maintance always
helps ;)
mike hunt
"badgolferman" <REMOVETHISbadgolferman@gmail.com> wrote in message
news:xn0eimqdh3wl3cr002@news.readfreenews.net...[color=blue]
> Currently I use Valvoline 5W-30 oil every 3000 miles.[/color]
Old 02-19-2006, 12:45 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Try tightening the valve cover bolts evenly.
There are no additives or oils that I am aware of that are effective in
reducing or eliminating the leak. I am not a fan of stop leak products
unless the vehicle is on its last leg because they have a tendency to clog
things if air gets into the system.
Ray O
Old 02-19-2006, 02:32 PM   #4 (permalink)
badgolferman
Guest
Posts: n/a
Ray O, 2/19/2006,12:45:56 AM, wrote:
[color=blue]
> news:xn0eimqdh3wl3cr002@news.readfreenews.net...[color=green]
> > Both gaskets have a slight leak with the front one being worse.
> > The dealer wants $690 to fix it. I am not going to pay that price
> > for it.
> in reducing or eliminating the leak. I am not a fan of stop leak
> products unless the vehicle is on its last leg because they have a
> tendency to clog things if air gets into the system.[/color]
Any idea what the torque should be for the bolts?
Old 02-19-2006, 10:22 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
news:xn0eio3y8e5ngg000@news.readfreenews.net...[color=blue]
>[color=green]
>> news:xn0eimqdh3wl3cr002@news.readfreenews.net...[color=darkred]
>> > for it.
> Any idea what the torque should be for the bolts?[/color]
I'm sure there is a spec although I just give the bolts 1 turn and see what
happens.
Ray O
Old 02-19-2006, 10:33 PM   #6 (permalink)
Gord Beaman
Guest
Posts: n/a
View Gord Beaman's Photo Gallery
"badgolferman" <REMOVETHISbadgolferman@gmail.com> wrote:
[color=blue]
Maybe Newfie tight?...(as tight as possible plus a half turn) :)
-Gord.
(use gordon in email)
Old 02-19-2006, 11:18 PM   #7 (permalink)
badgolferman
Guest
Posts: n/a
Gord Beaman, 2/19/2006,10:33:31 PM, wrote:
[color=blue]
>[color=green]
> Maybe Newfie tight?...(as tight as possible plus a half turn) :)[/color]
That sounds awfully tight. We don't even put that much torque into
airplane bolts.
Old 02-20-2006, 11:14 AM   #8 (permalink)
Gord Beaman
Guest
Posts: n/a
[color=blue]
>[color=green]
>>[color=darkred]
>airplane bolts.[/color]
Yer kidding me right?
-Gord.
Old 02-20-2006, 11:41 AM   #9 (permalink)
badgolferman
Guest
Posts: n/a
Gord Beaman, 2/20/2006,11:14:58 AM, wrote:
[color=blue]
>[color=green]
> >[color=darkred]
> Yer kidding me right?[/color]
Here's an example:
A 10-32 bolt in tension gets tightened to 40 lbs/sq in.
That's not as tight as possible plus an extra half turn. It's more
like snug plus another turn. However we use nuts with nylon inserts or
helicoil nuts where there is now way to use a nut.
Old 02-20-2006, 12:11 PM   #10 (permalink)
Mark
Guest
Posts: n/a
View Mark's Photo Gallery
Actually they're inch-pounds, not pounds per square inch. It's like a
force of 3 pounds applied at a right angle with a lever arm of just
over a foot (13.33 inches). In other words, not very tight at all past
being snug. Valve covers are thin and pretty easily distorted, which
will make the leak worse, not better.
As I recall, typical head bolts on old V-8 cars (like my '65 Merc) were
something like 70 FT-LBS, which is a LOT more force than those little
valve cover bolts.
I don't think you can completely fix a leaky valve cover gasket without
replacing it, but you might be able to slow it down by torquing the
bolts a bit (gradually and evenly, all around). Just don't break them
off... Alternatively, a new gasket is not that expensive and it wasn't
that hard to replace (at least not on my '87 Camry).
Old 02-20-2006, 12:53 PM   #11 (permalink)
badgolferman
Guest
Posts: n/a
Mark, 2/20/2006,12:11:27 PM, wrote:
[color=blue]
> Actually they're inch-pounds, not pounds per square inch.[/color]
Yes, you're right.
[color=blue]
> don't break them off... Alternatively, a new gasket is not that
> expensive and it wasn't that hard to replace (at least not on my '87
> Camry).[/color]
Was your 87 Camry a six-cylinder? It is much more difficult to do
those engines, especially the rear bay.
"Truth does not change according to our ability to stomach it." ~
Flannery O'Connor
Old 02-20-2006, 12:57 PM   #12 (permalink)
Mark
Guest
Posts: n/a
No, it was a four and pretty accessible... $650 seems like a lot in
any case
Old 02-20-2006, 10:16 PM   #13 (permalink)
Gord Beaman
Guest
Posts: n/a
[color=blue]
>[color=green]
>>[color=darkred]
Keeerist!...you 'did' see the smiley face on there didn't
you?!!...IT'S A JOKE PEOPLE!!
How the HELL does one tighten a bolt 'as tight as possible' PLUS
anything???...
Gee golly guys, it was a newfie joke!!...
-Gord.
Old 02-20-2006, 10:21 PM   #14 (permalink)
Gary L. Burnore
Guest
Posts: n/a
View Gary L. Burnore's Photo Gallery
On Tue, 21 Feb 2006 03:16:35 GMT, Gord Beaman <gord@islandtelecom.com>
wrote:
[color=blue]
>[color=green]
>>[color=darkred]
>anything???...[/color]
Easy. Put a long bar on the end of the wrench. Wait until you hear
the "click". :)[color=blue]
>Gee golly guys, it was a newfie joke!!...[/color]
gburnore at DataBasix dot Com
How you look depends on where you go.
Gary L. Burnore | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
Official .sig, Accept no substitutes. | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
| ÝÛ 0 1 7 2 3 / Ý³Þ 3 7 4 9 3 0 Û³
Black Helicopter Repair Services, Ltd.| Official Proof of Purchase
BB code is Off
Smilies are Off
[IMG] code is Off
Broke Valve Cover Gasket Bolt IN THE HEAD parimento1 1st Generation (1995-1999) 6 04-27-2006 09:38 PM
Valve cover gasket replacement White Buffalo Pre-88 Toyota Pickup/Hilux 1 01-02-2006 07:37 PM
90 4Runner with oil leak RangerZ 4Runner Lounge 2 10-05-2005 06:07 PM
HELP! Ran without oil due to leak Jakelukas Camry & Solara Lounge 4 08-14-2005 01:33 AM
pin pointing oil leak pepsi24chevy Camry & Solara Lounge 4 02-21-2005 05:28 PM
