Re: '99 Corolla Will Not Start
<hank755_ca@yahoo.ca> wrote in message
news:1140360620.851134.268950@g47g2000cwa.googlegroups.com...[color=blue]
> Hello,
> When I try and start my '99 Corolla, the lights come on and the radio
> starts but the engine doesnt crank at all. I've checked the battery and
> there's nothing wrong with it. It's only 2 years old anyway.
> Could it be the starter? How would I go about checking this? Is there a
> "quick and easy" way to determine this? Or could the problem be
> something else?
> Thanks in advance,
> H
>[/color]
If you have an automatic transmission, try shifting into neutral and see if
it starts. If it does, then the neutral safety switch is bad. Check the
battery clamps to make sure they are tight and free of corrosion. Otherwise
the contacts in the starter solenoid may be suspect. Check for power to the
solenoid. If there is power to the solenoid, then it is the culprit.
Ray O
