Re: 1982 Starlet electrical nightmare
On 19 Feb 2006 11:58:48 -0800, "derek" <derek_sacerdote@yahoo.com>
wrote:
[color=blue]
>I purchased this car used last year and have had constant problems such
>as battery draining after a very short time unused, snapping of the
>engine fuse disabling alternator, and car running after the key is
>removed. I suspect some type of short but I don't know where. I have
>replaced both battery and alternator to no avail. I fear these problems
>will cause alternator and battery to deteriorate.[/color]
My first thought is the alternator has an internal problem like a
bad diode that intermittently partially grounds out (high resistance
ground) and drains the battery, or totally grounds and pops the
fusible link/main fuse - Have you had a rebuild installed since you
bought it? On an '82 it might be an external regulated alternator,
or a first generation with the internal regulator.
One of the Dealer Techs that hangs out here may have heard of this
one happening before - and on a 24 year old model, they're liable to
have seen it a lot. The run-on problem could be related to an
electrical back-feed from the alternator failure warning light circuit
through to the ignition coil, but that's just a wild guess.
(But a lot of my 'wild guesses' tend to be close to the mark.)
Note that I am NOT saying "That's the problem, Change it" but the
alternator is the first item to check with a voltmeter and ammeter to
see what is going on - and check it with an oscilloscope if you have
one.
The output waveform will be all funky on the scope if you have a bad
diode - the alternator internally puts out three-phase AC power that
is rectified by the diode stack into DC, and when you drop a phase the
bad "AC Ripple" on the output line is very obvious - if you only have
a voltmeter, you'll see several volts of measurable AC Voltage on the
output line. The AM Radio will probably be un-listenable from
alternator whine.
And get the battery load tested, and check the manufacturing date
code - if the battery is old enough to be out of warranty, change it.
They go bad just from old age, and the warranty date is just the
median failure time they're saying you'll get past. Bad batteries can
ruin good alternators, and bad alternators can kill good batteries.
WARNING: DO NOT try running the car with the battery disconnected
or that main fuse blown! Depending on the design of the circuit, some
alternators will go full-field wide open when there is no battery in
the circuit, and they can send well over the normal 13-15 VDC out to
the rest of the car (50 volts or more) which can and will fry lots of
expensive things. This is bad.
If you go get the alternator rebuilt on general principles, get a
proper rebuild done - new ball bearings, windings checked thoroughly,
new brushes, new diode rectifier stack and new regulator. They buy
the parts in bulk, so it isn't that expensive to do it right.
The chain 'Beauty Auto Parts Stores' send them out and the cheap
rebuild shops they use only clean the outside, change what they think
are the "bad" parts, toss 'em in a clean box and ship 'em back out...
They figure the "Lifetime Warranty" will cover the come-backs.
I had one bad afternoon when the alternator died away from home and
a Kr***n was the only parts store around, it took R&R-ing four
[expletives deleted] alternators in their parking lot to find one that
worked.
(But it was swap the alternator there or chance 50 miles home at
night running only on the battery, which would be dicey. And if you
stall an automatic with a dead battery, now you're in deep [stuff].)
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
