Alternator belt tension 94 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2006, 03:03 PM   #1 (permalink)
Mr.E@totally.invalid
Guest
Posts: n/a
View Mr.E@totally.invalid's Photo Gallery
What is the correct deflection for the alternator belt on a 1994
Corolla with 7 series engine? Mine now has 1/2 inch measured at the
top motor mount with firm pressure. New belt has been run for a week.
Thanks
Mr.E
Old 02-19-2006, 03:15 PM   #2 (permalink)
njmodi
Guest
Posts: n/a
View njmodi's Photo Gallery
Re: Alternator belt tension 94 Corolla
The problem with measuring belt deflection is the ambiguity of the
"firm pressure" often cited. I typically just tighten it enough to
eliminate squeal. If you are worried that you have overtightened it,
you can back of the tension until you get occasional squeals (typically
on cold-starts for me), and then just tighten it a tad from there.
Nirav
Old 02-19-2006, 03:37 PM   #3 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
On 19 Feb 2006 13:15:18 -0800, "njmodi" <njmodi2@yahoo.com> wrote:
[color=blue]
>Nirav[/color]
What is a 'tad'?
.....the devil made me say it....LOL
Scott in Florida
Old 02-19-2006, 04:00 PM   #4 (permalink)
njmodi
Guest
Posts: n/a
oops - *takes foot out of mouth* ;)
Let's say 1 turn of the tensioner bolt :)
Old 02-19-2006, 06:51 PM   #5 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Sun, 19 Feb 2006 16:03:52 -0500, [email]Mr.E@totally.inva[/email]lid wrote:
[color=blue]
>Thanks[/color]
They make Belt Tension Gauges for manually tensioned V-belts (cars
without a spring tensioner on a multi-ribbed belt) - I have the Gates
'Krikit' which is inexpensive (around $10) and works like a torque
wrench. You'll probably have to order one at your favorite auto
parts, even though everyone should use one they rarely do when a
"calibrated thumb" will work, so the stores don't stock them.
You put it on top of the belt and hold a tape measure next to it,
push it till it 'clicks' and see how far down you went. They have a
little chart with belt sizes, span between the pulleys at the point
you checked it, and the proper setting range.
There are more expensive spring loaded gauges with three fingers and
a torque dial, you just clamp it on the belt and read the tension from
a dial gauge. If I ever find one for cheap, I'll grab it.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
BB code is Off
Smilies are Off
[IMG] code is Off
94 corolla timing 240_mark Archived Corolla threads 0 03-06-2005 02:26 AM
94 Corolla 7AFE EGR csc67 Archived Corolla threads 0 02-25-2005 06:00 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
4age swap into 94 corolla phil_preston General Discussion 1 05-23-2004 12:07 PM
Problem with 94 Corolla Ostornadoe Archived Corolla threads 7 05-17-2004 11:59 AM
