2002 RAV4 Internal Air Distribution Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2006, 04:45 PM   #1 (permalink)
FritterFran
Guest
Posts: n/a
View FritterFran's Photo Gallery
I have a 2002 RAV4 that has a potential internal air distribution
problem. I noticed it only on the left (driver) side. Due to the
cold weather here in the NE USA, I've had the heat on quite a bit.
I've noticed that when the heat is on, it will blow hot air through
all associated vents with the exception on the left side. This
includes the upper side vent on the dash by the window and the vent
under the dash for your feet. For these two vents, the air in the
"fresh" position blows "cool" air. This is not the case on the right
(passenger) side. There, the heat blows normally. Heated air from
the middle dash vents are fine as well. When I switch the system to
"recirculate" air, the cold vents warm up alittle.
What in the world could the problem be. Do I need to get behind the
dash to see what's up and if so, that type of screw bit do I need to
remove the dash. They look like torx but I'm not sure.
Thanks all in advance.
Fritter
Old 02-19-2006, 09:36 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 2002 RAV4 Internal Air Distribution Question
"FritterFran" <leave@mealone.cum> wrote in message
news:eqfhv1hssmifoujf59lc5ofb7i1oe0uefr@4ax.com...[color=blue]
> Fritter[/color]
check for an obstruction in the ductwork. The screws that look like torx
are torx.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
IAT (intake air temperature) sensor question Hamsterman Camry & Solara Lounge 16 09-13-2005 09:11 AM
1998 Camry Air intake question Batemada 3rd & 4th Generation (1992–1996 & 1997–2001) 2 08-07-2005 06:28 AM
AEM Cold air inatake help for 2002 GT topGUN Celica Forum 1 01-29-2004 08:50 PM
air pressure question rcj93cam Camry & Solara Lounge 8 04-12-2003 06:59 PM
Odd Question about my 2002 Camry XLE Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 3 10-13-2002 03:46 PM
