Re: Speedometer Tacho Signal, Toyota Avensis Lean Burn 1.8, year 2000
"Harry Jensen" <harry.mj@_REMOVE_THIS_gmail.com> wrote in message
news:43fa0a95$0$159$edfadb0f@dread11.news.tele.dk...[color=blue]
> Hi,
> Have just bought a GPS Radio, so now I need to know where I find the
> speedometer tacho signal.
> I found one on the net saying "black connector, on the back of the
> dashboard, pin 15", but that one didn't do it.
> Anyone having a better idea?
> Thanks in advance[/color]
Are you looking for the speedometer signal or the tachometer signal?
Re: Speedometer Tacho Signal, Toyota Avensis Lean Burn 1.8, year2000
Ray O wrote:[color=blue][color=green]
> Are you looking for the speedometer signal or the tachometer signal?[/color]
news:43fa565a$0$193$edfadb0f@dread11.news.tele.dk...[color=blue]
> Ray O wrote:[color=green][color=darkred]
> Sorry, the speedometer signal of course ;-)
> Brgds Harry[/color]
I do not have a wiring diagram for the Avensis, but if you look at the main
and tracer colors for the wires coming out of the speed sensor on the
transmission, it should follow all the way to the back of the instrument
cluster. You can do a continuity check to confirm.
>>Sorry, the speedometer signal of course ;-)[/color]
> cluster. You can do a continuity check to confirm.[/color]
Ok, I'll give it a try ;-), and should it be split somewhere and change
color, the continuity still is a good idea, there is only 40 sockets in
each connector, so I'll find it.
news:43fa601e$0$200$edfadb0f@dread11.news.tele.dk...[color=blue]
>> main
> Thanks..
> Harry[/color]
I'm think the speed sensor signal goes from the speed sensor to the
instrument cluster and then from the instrument cluster to the ECU. Good
luck!
Ray O wrote:[color=blue][color=green][color=darkred]
>>[/color]
I had hooked up to the pink wire, black connector socket 15 on the
dashboard, and that one is also coming from the speed sensor... but
there are two more wires, one going to ground and a blue one going to
the black connector socket 5 on the dashboard.... that's correct one.
The reverse signal can be found inside the cabin at RH side in a
connector just next to the ECU as a red/black wire.
news:43faf7bd$0$160$edfadb0f@dread11.news.tele.dk...[color=blue]
>>>[/color]
>> main
> The radio type: Blaupunkt TravelPilot E1.
> Thanks to Ray for the hints ;-)
> Brgds Harry[/color]
