Re: Importing a used Diesel motor to the USA for a Toyota Previa
<matt.and.chiaki@gmail.com> wrote in message
news:1140474601.607417.215000@g47g2000cwa.googlegroups.com...[color=blue]
> Hi,
> I live in the USA (Seattle, WA) and have a question about importing
> *just the engine* for a Toyota Previa
> I know the Toyota Previa has a diesel option in other parts of the
> world,
> and the US does not allow importing Diesel vehicles... is it possible
> to just
> import the motor only?
> Thanks,
> Matt
>[/color]
Yes, you can probably import a diesel motor only. However, to convert the
Previa into a diesel-engine vehicle, you would need at least a new fuel
tank, fuel filler neck, fuel pump, fuel lines, transmission, ECU,
transmission ECU (if you have an automatic transmission), brake booster if
the engine does not include a vacuum pump, and engine wiring harness. You
will probably also need a new dashboard wiring harness, ignition switch,
instrument cluster, and cooling system. If the engine does not include a
starter, you will need a new starter. After you spend somewhere in the
vicinity of $10,000 to $15,000 to convert the vehicle, you probably will not
be able to pass any emissions tests or get it repaired.
Ray O
