Corrola when A/C on Engine output not stable? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2006, 10:21 PM   #1 (permalink)
fengyie@yahoo.com
Guest
Posts: n/a
View fengyie@yahoo.com's Photo Gallery
Hi,
This issue has been botherd me since I got this 2004 Corrola. When I
turen on the A/C, the engine's output seems become not stable. The
dangerous situation is when I am tring to park the park, the egine
sometime suddenly gives out a strong push and because of the soft brake
comes with the Corrola, I will feel that the I may be lossing control
over the car and thank god every time I can just stop the car before it
hits the wall.
Then , here is the question, is it normal that with the A/C turned on,
the engine's output can suddenly increase by itself?
Thanks alot.
Feng
Old 02-20-2006, 10:28 PM   #2 (permalink)
fengyie@yahoo.com
Guest
Posts: n/a
Re: Corrola when A/C on Engine output not stable?
Sorry , typo here, I was trying to say" When I am trying to park the
car".
Sorry again for the mistake :) cause my wife was watching me typing...
feng...@yahoo.com 写�:
[color=blue]
> Hi,
> hits the wall.
> Thanks alot.
> Feng[/color]
Old 02-21-2006, 12:08 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
<fengyie@yahoo.com> wrote in message
news:1140495690.877505.288090@g47g2000cwa.googlegroups.com...[color=blue]
> Hi,
> hits the wall.
> Thanks alot.
> Feng
>[/color]
When the AC is turned on, the engine's output does not suddenly increase by
itself. When the AC is on, the AC and engine controls may increase the idle
speed. Also, when you are turning the steering wheel at low engine speed,
the power steering pump will also send a signal to slightly increase engine
speed.
Ray O
Old 02-21-2006, 01:24 PM   #4 (permalink)
Jimbo
Guest
Posts: n/a
View Jimbo's Photo Gallery
I have seen a similar situation with a 97 Tercel and have always
attributed it to the "small" engine and powerful ac. It is because the
idle speed is increased automatically when the ac is switched on. If
it bothers you, I suggest you turn the ac off while parking :)
Old 02-21-2006, 04:40 PM   #5 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
On 21 Feb 2006 11:24:11 -0800, "Jimbo" <jfroche@gmail.com> wrote:
[color=blue]
>it bothers you, I suggest you turn the ac off while parking :)[/color]
I turn my AC off when accelerating my '92 Corolla Wagon....
LOL Only way to get to speed in a years time....
Scott in Florida
Old 02-22-2006, 01:36 AM   #6 (permalink)
fengyie@yahoo.com
Guest
Posts: n/a
Thanks for you guys replies.
I think your answers make sense. I tried it out again today, when I
turned on the AC, the Idle speed is pretty high( around 1000rpm) and
the output seems to be pretty strong. I needed to spend extra effort to
stop the car by pushing the park peddle obviously harder. I hope it's
not because of the AC 's problem which causes the engine to give out
too much power.Other than that I will have to live with it. The work
around will be either turn off the AC when I am parking or use extra
caution.
Thanks,
Feng
Old 02-23-2006, 02:36 PM   #7 (permalink)
Mike Hunter
Guest
Posts: n/a
View Mike Hunter's Photo Gallery
Unlike the old days modern vehicles, that are controlled by a micro
processor, no long need to change the idle speed when load is applied to, or
removed from, the engine. The MP adjusts the fuel air ratio to handle the
increased load rather than increasing the RPMS. The RPMS should remain the
same.
mike hunt
news:1140593819.238897.230430@g43g2000cwa.googlegroups.com...[color=blue]
> caution.
> Thanks,
> Feng
>[/color]
Old 02-23-2006, 04:03 PM   #8 (permalink)
timbirr@mailcity.com
Guest
Posts: n/a
View timbirr@mailcity.com's Photo Gallery
Mike Hunter wrote:[color=blue]
> same.[/color]
Hmm, tell that to my 03 Camry. Idle has always bumped up when the AC is
on, since the day I drove it off the lot with 11 miles on it.
Old 02-23-2006, 08:29 PM   #9 (permalink)
Gord Beaman
Guest
Posts: n/a
View Gord Beaman's Photo Gallery
[email]timbirr@mailcity.com[/email] wrote:
[color=blue]
>Mike Hunter wrote:[color=green]
>> same.[/color]
>on, since the day I drove it off the lot with 11 miles on it.[/color]
Of course...I've never seen a modern automobile with AC which
doesn't 'idle up' when the compressor cuts in, why do you suppose
they call it an 'idle up circuit'?...gee...
-Gord.
(use gordon in email)
Old 02-24-2006, 08:13 AM   #10 (permalink)
Jimbo
Guest
Posts: n/a
Maybe I've just been unlucky in all the vehicles I've had :) Every one
of them, from a variety of manufacturers "idles up" when the a/c is
switched on. It's just more obvious with the Tercel, IME.
Old 02-24-2006, 02:03 PM   #11 (permalink)
Mike Hunter
Guest
Posts: n/a
Perhaps you haven't looked at a modern vehicle, with the latest technology,
only at a four year old Toyota low end econobox. 800 RPMs are more than
enough to run a rotary compressor. Look at a 2004/6 Lexus and many
domestics with individual cylinder injectors and coil packs. Many do not
even have the throttle connected directly to the engine. Some modern cars
with that technology can even run perfectly fine with less than all the
cylinder ;)
mike hunt
"Gord Beaman" <gord@islandtelecom.com> wrote in message
news:onrsv1piqv21m773urk3m0e9c2mola6u5d@4ax.com...[color=blue]
>[color=green]
>>Mike Hunter wrote:[color=darkred]
>>> to, or
>>> the
>>> the
>>> same.[/color]
> -Gord.
> (use gordon in email)[/color]
Old 02-24-2006, 05:45 PM   #12 (permalink)
Gord Beaman
Guest
Posts: n/a
"Mike Hunter" <mikehunt2@mailcity.com> wrote:
[color=blue]
>same.
>mike hunt
>[/color]
You sure about that Mike?...doesn't make a lot of sense to
me...I'd have thought that the idle mixture would have been set
near 'best power' for normal operation.
I always thought that the 'idle up' circuit just increased the
idle speed somewhat by opening the butterfly slightly so that the
added load of the compressor wouldn't 'bog the engine down'.
Doesn't make sense to have the idle MIXTURE set so as to provide
the 'idle up' feature.
-Gord.
Old 02-24-2006, 07:38 PM   #13 (permalink)
Mike Hunter
Guest
Posts: n/a
It is apparent if the vehicle has a tack. Newer vehicles, primary from
Toyota and Ford, hold the idle around 800 RPMS. When one moves the gear
selector, the idle will drop down for an instant, then come back to 800.
After selecting neutral the opposite takes place. Start the AC and it will
once again drop down for an instant then come back to 800. Then the opposite
takes place when the AC is turned off. It is all done within the MP as it
detects the increased or decreased torque and adjust the F/A ratio. Better
fuel economy and reduced pollution are obtained by doing it in that manor.
That is the beauty of the most modern MPs. Once the vehicle is up to
operating temperature the 02 sensor sends a controlling signal to the MP,
over a range of 4 to 20 milli-amps, (1V to 5V,) all the time to maintain the
most efficient F/A ratio in all situations, based on the other four of five
imputs , . That is why the throttle is connected to the MP and no longer
directly to the engine fuel supply. With the old carburetors the throttle
controlled air flow. With the first injectors it controlled fuel flow, now
it simply controls demands for more of less torque and the MP sets the F/A
ratio to suit that demand. That is why big V8 engines today, like the 300
HP 300 FP of tongue in my Mustang GT, get 25 MPG or more with ease. They
produce gobs of torque and more than adequate HP with minimum fuel demand
mike hunt
news:kr5vv1do514ttvprtn980qdng9hl5p907o@4ax.com...[color=blue]
>[color=green]
>>or
>>the
>>same.
>>mike hunt
>>[/color]
> -Gord.
BB code is Off
Smilies are Off
[IMG] code is Off
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
Camry Engine specs and possible swap Firestorm8319 Camry & Solara Lounge 17 09-29-2005 02:11 PM
Increasing Horsepower in an AE92 azpriz90 Archived Corolla threads 5 01-11-2005 07:47 PM
need engine bay pics of 86gts with a/c toyotahachiroku Archived Corolla threads 0 04-13-2003 06:11 PM
