Paseo cooling fan - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2006, 08:10 PM   #1 (permalink)
Rhys Pieces
Guest
Posts: n/a
View Rhys Pieces's Photo Gallery
Paseo cooling fan
Our '93 Paseo 5 speed has two cooling fans. The problem is, the one near the
battery runs constantly from startup (stone cold). The engine never warms up
past 'C' on the temp gauge. When I disconnect the wiring terminal at the fan
it warms up fine, just runs warmer than normal with a new 'stat. I can see a
single loose wire with a bare end coming from the area of the temp sensor at
the bottom of the radiator. It's to dark out to see now but I was wondering
if this is the fault. I don't know Toyota's theory of how the cooling fans
are supposed to operate but it is hard to imagine one fan would run from
start up. If the loose wire is not the problem, where is the potentially
defective relay located if it needs replacing? Thank you for any advice.
Old 02-22-2006, 09:06 PM   #2 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
Re: Paseo cooling fan
On Thu, 23 Feb 2006 02:10:21 +0000, Rhys Pieces wrote:
[color=blue]
> defective relay located if it needs replacing? Thank you for any advice.[/color]
The good news is, the fan is doing what it's supposed to. When there is a
fault, the fan will stay on all the time. Better to run a little cold,
give up some fuel economy than blow a head gasket.
The not so good news is, that wire is proably the culprit. Hope it isn't
too cold this weekend! If you're lucky, you may be able to splice it back
together, and then tuck and/or tie wrap it to keep from snagging something
again.
I always wanted to get one of these and istall the 4A-GE engine it should
have had in the first place...
In the grand scheme fo things...
What difference does it make?
Old 02-22-2006, 11:29 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Rhys Pieces" <rhysgt@pacbell.net> wrote in message
news:hQ8Lf.24106$_S7.20622@newssvr14.news.prodigy.com...[color=blue]
> the
> up
> fan
> a
> at
> wondering
>[/color]
One fan operates to control coolant temperature, the second fan operates
with the air conditioner. As Hachiroku suggests, fix the bare wire and you
should be good to go.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
My Electric Fan Mod is Complete! Pb 2nd Generation (2005+) 116 08-13-2009 11:34 PM
Electric Cooling fan and Overheating riddlej Cressida Forum 0 12-19-2005 12:33 PM
help- cooling fan. playa69 Archived Corolla threads 14 09-28-2005 01:46 PM
Cooling Fan DebbieSzc Yaris, Vitz and Echo Forum 3 11-20-2004 11:38 AM
cooling fan function related to ac high press switch chitowncelica Hardcore Tech and Competition 4 07-22-2004 04:15 PM
